Holley Dominator Question
Old 06-25-2019, 03:56 PM
RonSSNova's Avatar
Default Holley Dominator Question
Got a car in the shop to complete then tune.
I noticed that there is no Manifold Absolute Temperature sensor.
I know in the GM factory system, it needs to be there.
I’d think the Holley would as well?
There is certainly a connector for it.
Ron
Old 06-25-2019, 04:28 PM
lemans1's Avatar
Yes there is a connector for the MAT/IAT. You could zero out all of the tables that use it effectively removing it, but why not just add one? They're cheap and readily available.
Old 06-25-2019, 06:06 PM
pdxmotorhead's Avatar
15 bucks and a hole in the intake,, or IIRC the dominator has a un-used port for vacuum that it fits in,, center back of the carb in the base...
Old 06-25-2019, 07:23 PM
RonSSNova's Avatar
Car will be non intercooler in methanol. But data is always good.
carb?
Old 06-25-2019, 07:58 PM
truckdoug's Avatar
he's thinkin you have a holley street dominator intake manifold
Old 06-25-2019, 08:02 PM
truckdoug's Avatar
i have the terminator, which i think is really similar software. I plan on using the gm IAT sensor...the data for the gm sensor is populated in the drop down menu...as well as a couple others...chrysler, ford etc
Old 06-25-2019, 08:26 PM
RonSSNova's Avatar
It does have a Dominator intake on it.
The one threaded port is being used.
Holley sure could have added more vacuum/boost sources on that thing.
I’ll have to buy a multi port manifold for it to connect the FPR, BOV etc to. That stuff all needs to be finished.
Edelbrock got it right on their intakes.
And I meant it’s going to run on methanol.
Thanks Doug. I’ll shoot you some photos.
Old 06-25-2019, 11:16 PM
truckdoug's Avatar
i think thats the holley high ram in the pics you sent me
the dominator is a single plane carb intake. I had one in the late 90's haha I can still smell the unburnt fuel
Old 06-26-2019, 06:16 AM
forcd ind's Avatar
The Holley only has the IAT (MAT) lead, mont. incoming air, but you prob could put the
sensor anywhere. I know some guys will use it as a safety if intake air temps get
to high, some add fuel to kill it, not sure how that works out.
Old 06-26-2019, 04:26 PM
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
Ron
If it has a Holley HiRam, there is a port in the ear that takes a stock MAP sensor. Also, the cast pad in the back of the Hi-Ram is pretty big, so extra holes can easily be added.
Andrew
Old 06-27-2019, 08:38 AM
RonSSNova's Avatar
Thanks Andrew.
I ordered a vacuum/boost manifold that will get me all the ports I need.
There are numerous items to fix and complete on this car before we even attempt any dyno work.
Ron
Old 06-27-2019, 05:44 PM
Thanks Andrew.
Ron
Glad to help Ron. A manifold is a good idea and should be mounted off the engine, so that the sensors don't vibrate.
Andrew
