What are the signs you maxed out your LS2 / LS3 fuel rail?
I have the LS2 / LS3 fuel rail and since I have a turbo, I'm going to need a lot of fuel for when I turn up the boost. What are the signs you maxed out your fuel rail?
Increased injector duty cycle? WB goes lean no matter how much fuel you add at WOT?
I did some searching on here and Google, but it seems that people just say a HP number without ever saying how they found out. Anyone ever do any real testing or are they just guessing?
I gotta ask, what are the real HP limits of the LS3 fuel rail?
What are the limits of the fuel rail being dead headed? Has anyone ever done any real testing with info to back it up?
I know I won't make 1000 RWHP but where does it max out at? With as many views this has received so far, I'm going to guess that no one had actually did any real tests.
A lot people upgrade to aftermarket fuel rails but did they really need to? Is it good old fashion marketing?
Restricted User
Power will depend on fuel used, fuel pressure, etc.
You could probably do 1200whp with them under ideal conditions. The only way to know whether or not your conditions are ideal is to get it together and find out what it does.
Single 3/8" feed line has made over 1500 horsepower at the flywheel on oxygenated race gas before.
The question is not just for me but for others as well. There is a local guy with a 2010 Camaro M6, forged 416 LS3, ported heads, turbo cam, 88mm Turbo that I'm helping out. He bought the car recently, already built, but wants to turn up the boost. It also has a stock LS3 fuel rail but with aftermarket fuel pumps.
Has he logged anything? Read plugs? Is it stock fuel system with just pumps or a return style off the stock rails with a new feed? 93 or E85? What base fuel pressure and static or 1:1 boost referenced? There's not a 1 size fits all XXXX hp limit is the threshold. Common sense goes a long way.
If you want, I can waste my time and a write novel about the 2010 Camaro but I doubt that will help find the info I'm looking for. There is a limit for everything in life,
"I have the LS2 / LS3 fuel rail and since I have a turbo" turned into "My buddy....". Your question has been answered on A) power level and B) how to test and see if you're a candidate for rails. You just dont want to listen to either so whats the point of this thread again?
No, the story has not changed at all, you guys must like stirring the pot.... We both have LS3 fuel rails, the same part, how is the story changing?
Let's make it super easy for you: LS3 fuel rail, 58 PSI, 93 octane fuel, FIC 1000cc injectors, no return off the shrader port (dead head) , 1:1 boost reference fuel pressure regulator, upgraded supply line, unlimited fuel pump supply.
I'm not trying to start a debate or anything, just want to know what the LS3 fuel rail can really support with real world testing. I'm starting to realize that no one has actually done any real testing, just guesstimate and roll with it.
At first you were speaking about YOUR setup, then further down you refer to your BUDDY'S setup. At no point was it said you were referring to two different setups. Hence the confusion.
Restricted User
Your question isn't LS3-rail specific, but you seem to want LS3-only numbers.
I just wonder if the LS3 fuel rail can support more HP than most people think it can. I know it won't support 1,500 HP but I'm going to guess more than 750 HP with an average LS boosted setup.
