Car went dead
Car went dead
Battery was a little weak so I jumped it with annother car. Drove it around the block a few times with no problems. Went to pull into the driveway and it just died. Hit the key and nothing, no lights , no clicking, nothing. checked all the fuses, all good. anybody????
Check all your battery connections
Start with the a good healthy battery and have the alternator tested.
Your alternator must be bad. Your car will run for a short time using the battery power until it gone. Old rule of thumb: you can remove a battery terminal from a run motor and it will not die, but if he alternator is bad motor will stall out.
A bad cell can intermittently cause a battery to be dead. I think your bad cell went from bad to worst.
I was just adding to what G Atsma had said and when you lose everything like that it's due to a faulty connection somewhere. I've seen it happen with my truck which turned out to be a loose connection at the battery terminal.
Oh yeah I've heard its not a good idea to test an alternator like that in today's cars due to the fact the system needs the alternator and battery to be in good working order.
