E85 only GenIV 4.8L: order of restrictions?
Old 07-23-2019, 12:02 AM
deucesallin's Avatar
Default E85 only GenIV 4.8L: order of restrictions?
Can anyone confirm that this the order of fueling problems on a bone stock GenIV FFV 4.8L truck motor runing boost and E85?
1) INJECTORS & PUMP finish around ~400ish WHP
2) FPR then gets overpowered by the new pump/pumps
3) LINES & RAILS (if still stock by then) domt need attention until 700-ish?
So a large drop in pump+FPR+returnless fuel system conversion should get me close to 700whp on factory rails and lines?
-asking for a friend,
Old 07-23-2019, 06:32 AM
Restricted User
JoeNova's Avatar
Something like that.
Old 08-10-2019, 05:41 PM
With HP Tuners to control the factory FPR and pump, how much boost can I run without an external regulator?
I would like to get this thing running under boost, even at 6 or 8 PSI and play with HP Tuners before stepping up the fueling and valvetrain. Whats the simplest method to get there with a bone stock FFV GenIV?
Thanks,
Jake
Old 08-10-2019, 06:00 PM
Kjduvall's Avatar
Walbro 450, convert to an lines , in line flexfuel sensor, and appropriate injectors. With aeromotive boost refranced regulator. And pull out the fuel pump controller. And replace with a hot wire kit. That's how I did mine and it's stupid reliable!!!
