First turbo build, 70 GTO...
I have been a member of this forum for a long time. Have done several LS swaps, but this is my first turbo build.
The car is a 1970 GTO, the original LS swap build thread can be found here:
https://ls1tech.com/forums/conversio...ion-2-0-a.html
The latest iteration of the build can be found here:
I originally wasn't going to do a turbo build, but after this years LS Fest, I got the bug. Getting Covid 19 would have ben less expensive...
The goal was to have a very reliable combination that could be driven anywhere. I like driving my cars a lot. My Cougar LS build has about 30K miles on it since I built it in 2015. Build thread here is anyone is interested:
https://ls1tech.com/forums/conversio...gar-build.html
Other goals are 850-900 crank HP and quick response. The car is heavy and the goal is to drive it to LS Fest, run mid 10s (or quicker) and drive home.
The engine combination is locked in. It is an aluminum 5.3L that used to be in my Cougar. It now has Molnar crank and rods and Wiseco pistons. It has ARP main and heads studs and Cometic head gaskets. Heads are 799 castings with Manley stainless valves, valve job, Trick Flow springs, trunion kit, and Summit Ghost cam (aka stage 1 turbo cam).
The turbo is being built by Work Turbo and is their S4E model. It is based on the BW S400 series bearing system and will have their 72mm billet compressor wheel and the 83mm turbine wheel. The turbine housing is from Tial with a 1.17AR.
Hotside will be the Holley single cast log system. Trans is a 4L80e with a converter to be determined. Everything run by a Holley Dominator ECU.
Any and all comments are welcome. I know I could have achieved my goals for less money, but having something that was reliable was important. I have my fire suit on, so flame away, I don't mind...LOL
Andrew
Andrew
Sounds like a solid plan. What are you thinking for fuel? Won't need anything crazy for that power.
Project GatTagO (12-03-2021)
The following 2 users liked this post by Project GatTagO:
jayyyw (12-04-2021), The BallSS (01-26-2022)
The turbo is being built by Work Turbo and is their S4E model. It is based on the BW S400 series bearing system and will have their 72mm billet compressor wheel and the 82mm turbine wheel. The turbine housing is from Tial with a 1.17AR.
Andrew
Andrew
The following 2 users liked this post by gametech:
Project GatTagO (12-04-2021), The BallSS (01-26-2022)
John,
I struggled with every decision for this project. My original plan was to use a Holley LoRam with a Tick Performance A2W intercooler. Then I thought that the LoRam was going to be terrible for low-end response, so I thought about using a stock style intake and doing a A2A up front. Well, because of the way the GTO has the supports for the endurance front bumper, it was going to be a nightmare to get the cold-side piping done. Then I thought, **** it, I am just going to do W/M injection and no intercooler. Well, I think at the boost level that I want to run (18-20psi) that just isn't going to work very well. Long story short, I am back to the Tick intercooler and LoRam.
You are too kind, Sir. LOL
Andrew
Andrew
LS1Tech Co-Founder
I don't want to add to your pain lol but I was researching the low ram for a buddy looking to keep a stock hood on a 2nd gen Camaro, and the feedback I was getting was a mix of stay high ram, go BTR, stock intake, or Pro Flo. I think also not many folks have run the low ram and there is not really enough data out there.
Are you going triple disk converter?
Yes, triple disk converter.
Andrew
I have fit some IC'ers in tight places, but it comes down to how much cutting are you willing to do, some cars I just wouldn't cut on. I was looking at one of those barrel style like Frozen Boost has, rated to 1200 HP, add a pump and small heat exchanger, or small rad. Spray meh can be an option, using that now with 93 octane. Small things like ducting the intake out of the engine comp. can help IAT's. The flex fuel sensor is always a great idea, cruise on 93, add E85 to raise the eth content, let the tables change the tune. With your tuning skills, that's a slam dunk. I would imagine you want full exhaust, with the S400 turbine housing you will have a min of a 4" downpipe, gets tight even if you dont have AC, on my A body I ran 4" to the rear bumper, but splitting it underneath to 2-2.5 is quiter, easier fit. Number 8 spark plug access pretty much sucks, makes me wish I had a Procharger, lol. Looking forward to this build, you build some neat stuff.
I have been taking some inspiration from Alex's 68 Impala build:
https://ls1tech.com/forums/conversio...hp-17-psi.html
The way he did his A2A intercooler might be an option, although the engine would need to be installed just to see how much room I actually have to work with. Another option I thought about was getting a radiator that was 4" narrower. This would give me a window through which I could pass intercooling pipes through.
I did think about using water/meth only. I am not sure that it would be a viable option at the 20 psi range, but I am open to input. It would certainly make for the easiest packaging.
I plan to build a 4" downpipe and have plans for a cutout, roughly under the passenger seat. I really want to maintain a stock look for the exhaust, which complicates matters. The GTO used a unique dual exhaust system where the pipes exit through the lower valance. Should have built my 6.2L and added a Magnuson Heartbeat system...
Andrew
LS1Tech Co-Founder
Never saw that build thread, it made for some good reading today. He's local too, I wouldn't mind checking that car out.
Magnuson would be quicker and simpler to swap on, but 800hp makes the turbo worthwhile I think.
LS1Tech Co-Founder
My radiator core is only like 20.5 wide and I'm running a single 16" fan, so far it's been keeping up, the hottest the car ran was 204F sitting in barely moving traffic for a few miles.
This video was posted in this forum, and I am only using it as an example:
I definitely don't want it to respond like this. Any thoughts on how to keep that from happening?
Andrew
Andrew
John,
