Cam recomendation for turbo 6.0
Old Aug 20, 2023 | 07:47 PM
Will-L's Avatar
Default Cam recomendation for turbo 6.0
Looking for a can recomendation on new build.
lq4 6.0
799 heads
4l80e
vsr75/78
3600 stall
not a daily driver but a driver so street manners are a concern
thanks
Old Aug 20, 2023 | 10:38 PM
slothman's Avatar
call TSP they will know what you need
Old Aug 24, 2023 | 05:47 PM
Utinator's Avatar
The Summit stage-1 turbo "ghost cam" is very street friendly. I recently built a 6.0L (bored .030" over) with this cam. It idles smooth, and made 490hp with LS3 top end (10:1 compression).
Old Today | 05:55 AM
sum guy's Avatar
I have a very similar set up. Vs racing 78/75 1.25 ar ,vs racing 50mm waste gate, no blow off valve, 4l80e, 3.50 gear, stock cam, pcm, head gaskets, bolts. 60lbs injectors, duel 340’s in the tank, but one is enough . I wish I gapped the rings while the engine was apart and went with bigger injectors, 8an feed ( going e-85) Right now I’m having a blast with it on 7lbs!
