VVT Truck Cam Dyno Results 6.2 L94 V8
The engine: 80k mile 2014 L94 from a Cadillac Escalade. DOD delete, 823 heads ported and hollow stem intake valves by Frankenstein Engineering Development (their Torq-R CNC program), Cam Motion custom 214/224 113.5+8 with .553" lift, LS3 valve springs, Speed Engineering Headers and 3.5" single exhaust with tailpipe, stock intake, RPM Level 6 4L60 with FTI 2600 11" converter. Tune is by DrTuneEmAll. Vehicle was dyno'd with 3.23 rear axle and the transmission in 2nd gear. The rear axle has been upgraded to 4.10 since then.
The truck was originally a 4.3 V6 that was so slow, I wonder if I could outrun it on foot.
Now, with the V8 and 4.10 gears, it is fun to drive. Sometimes I just make excuses to go for a ride.
You can see how retarding the camshaft really extends the RPM of this little truck cam. This is really noticeable during shift recovery, especially the 1-2 shift because the of the gear spread of the 4L60. When you take it to 6600 RPM the truck keeps pulling after the shift whereas if you shift at 6000 RPM it really falls on its face when it hits 2nd.
