Safe RPM limit for built LS6
Old Aug 17, 2024 | 01:31 AM
v1.5's Avatar
Default Safe RPM limit for built LS6
Hi, I have an 05 cts-v and am building the motor right now with eagle rods, ARP rod bolts, summit pro ls pistons and a tick cam, 3/8” hardened pushrods and dual valve springs. And a melling 10295 oil pump. Just curious how much I can safely increase redline to. I was thinking maybe 7000.
Old Aug 17, 2024 | 07:43 AM
Woodylyf767's Avatar
What are you concerned about ? Rod Bolts or valve train?
There's a lot more to it than just RPM
Old Aug 17, 2024 | 09:50 AM
bthomas's Avatar
Valvetrain is what will limit you. Solid roller isn’t a hard requirement at 7k, but it will definitely be more stable than a hydraulic.
Old Aug 17, 2024 | 11:58 AM
Kfxguy's Avatar
I have a GTO, came with an LS6 bottom end. Had a 228/232 cam in it and I turned it 7200. I ran the **** out of it, then put a turbo on it just like it was. Still 7200 with the turbo. Then I changed the cam to a 222/233 because i didn't like how the bigger cam drove. Never had a rod failure, I broke a ring land from too much timing on pump gas. i still have the engine on a stand. It'll take 7200 no problem.
Old Aug 17, 2024 | 07:34 PM
RB04Av's Avatar
Safe RPM limit for
It's all in your head. Whatever YOU feel comfortable with, THAT'S the "limit". The parts have little or no bearing on it. Of course, whenever it grenades, you can blame it on something else besides poor decision-making on your own part; and the longer it runs as-is, the more credit you can give yourself for masterful "building". Human mental gymnastics are wonderful that way.
How much of the right shade of red paint have you got? Knock yourself out.
Enjoy your build.
Old Aug 18, 2024 | 09:34 AM
kinglt-1's Avatar
I would say thousands of people with LS engines have done this.
I revved a 2002 LS1/ LS6 block with a XE 224/228 112 cam to 7000rpm for years. Good springs, lifters, and proper lifter preload will allow for it. It had TEA stage 1 243's with the LS6 valves and a ported Fast 92.
Pretty standard imo. No need to start overthinking things unless you are trying to push 7500+.
Old Aug 18, 2024 | 01:39 PM
LilJayV10's Avatar
I've spun my SBE LS1 to 7200rpm for years then added 15lbs of boost. The rods are still in it...so far.
Old Aug 19, 2024 | 02:15 PM
Bob570's Avatar
With a forged bottom end and ARP rod bolts, you should be fine to 8000+ rpm no problem. Your valvetrain will be your limiting factor. 7500 RPM isn't terribly difficult to achieve, I would probably want a good link bar lifter for that though.
But if the setup in your signature is still accurate, I don't see any reason to set the rev limiter over 7200-7300.
 Michael S. Palmer
Old Aug 20, 2024 | 04:37 AM
CaseyPrice's Avatar
Replying for the updates.
Old Aug 20, 2024 | 08:23 AM
Old Buzzard's Avatar
Thumbs down Huh??
^^^^ TROLL someplace else.
Old Aug 20, 2024 | 10:26 AM
madmike9396's Avatar
Really depends on the cam.
Old Aug 23, 2024 | 01:56 PM
02EBC5Z06's Avatar
I ran my ls6 stock bottom end to 7600. Where the car peaks power at is going to be dependent on the manifold/top end and your valve train stability.
My combo consisted of a btr stage 4 ls3 cam from 2017 (so not their current grind technology, 233/250).. Hi ram with shearer lid, 1" nitrous plate, 103 tb, tfs 220s with turned down ls3 valves, johnson 2126 short travels, 11/32 manton pushrods.
The car peaked power around 7000 or so, we had the limiter set at 7800, so where exactly I shifted is a gray area lol.. But it was right around that 7500-7800 range without losing momentum and giving me good shift drop rpm.
Old Aug 23, 2024 | 04:52 PM
grinder11's Avatar
Asking sincerely-What is different about an LS6 bottom end compared to the LS1? AFAIK, and IIRC, they both have the same crank and rods. IIRC, the LS6 used a different block for a short time before the LS1 got the same block.....
Old Aug 23, 2024 | 05:12 PM
Kfxguy's Avatar
the ls6 bottom end has holes drilled in the rod throws for lighter weight. The rods are the stronger floating pin rods. The block has windows in the webbing for better ventilation. That’s what I noticed on my ls6 bottom end vs a regular 5.3 (should be the same as ls1). Except for the GTO ls1 which is actually an ls6 short block with crappier heads than an ls6. I have the gto short block.
Old Aug 23, 2024 | 08:41 PM
grinder11's Avatar
I learned something today! Never had my LS1 apart. Sold it to put the LS7 in. Now... That LS7 has been apart, Lord knows!!!!
Old Aug 28, 2024 | 04:07 AM
Pulse Red's Avatar
Interesting. Not that it makes much difference, If the 04 GTO got the LS6 block, I wonder if the 04 Monaro did too. I've never thought to check.
Old Aug 28, 2024 | 10:08 AM
I would almost bet on it, as the GTO is only a rebadged Monaro.
Old Aug 28, 2024 | 10:54 AM
99 Black Bird T/A's Avatar
FWIW - When I wanted to use a new spare LS6 block for my 383 LS build, the engine builder said save it for a high rpm build. He said the LS6 block could make a sweet 7,500 to 8,000+ high rpm screamer 😱 no point to waste that on a low rpm stroker build. Stable valve train being the challenge etc.
Old Aug 28, 2024 | 04:51 PM
Pulse Red's Avatar
GTO got a different engine spec to the Monaro in 2004, and a completely different engine in 2005 (LS2 for GTO, Monaro stayed with the LS1). The specs of the cars in general were quite different. So, its not a given, I'll have a look when I get the car out next.
Old Aug 28, 2024 | 06:41 PM
wlink14's Avatar
For a while before I installed my turbo I was revving my forged internal 6.0L to 7200rpm. Really basic stuff for valvetrain. Hardened pushrods, TFS .660 valve springs, trick flow lifters, trick flow .560 lift cam. 799 heads so heavy valves. No issues. I had no reason to rev it that high other than I thought it sounded cool.
Cam was probably all sorts of done by 6400rpm.
I turned it down to like 6600rpm after I figured out that auto transmissions don't like that much rpm
