Car covers
In Florida there is no such animal as an affordable car cover. You either get the top of the line that costs hundreds of dollars or you avoid covers completely As you stated, the intense FL sun, especially in the summer, destroys all covers in time. The cheaper they are, especially Chinese crap, the faster they deteriorate. Another HUGE negative are those summer monsoons. The moisture and heat get trapped underneath even with the finest covers. Paint issues can arise and there can be a 'stink' too that gets into your air system that takes awhile to clear out. Love bugs on your ride? Don't even think about a cover.
I lived in FL for most o my life until retiring here to NC. My cars were either garaged or left out in the mercy of the elements. It was better than a car cover.
I've learned a lot about outdoor car covers in the last several years. Even the really well made expensive ones will only give you 1-2 years of "total" protection if they are exposed to a constant barrage of sunlight and weather extremes, after that they will start to leak and allow dirt to pass through. The cheaper ones are only slightly worse, but the primary difference I have found is that the cheaper ones will beat the crap out of the paint, even if the car is very clean before covering it. The more expensive ones won't trap moisture and won't damage the finish (unless the car is very dirty).
If you can park in any kind of shade, the cover will last much longer. Full sun will really shorten its lifespan, but if not for the cover then the car itself would be taking the brunt of that UV damage. It's shocking how much UV protection you can get from a good cover if you replace it before it deteriorates too much. When folks look at my '74, they are surprised to find out how long it's been sitting outside under a cover and still has stayed so nice.
With all of that said, we only have intense UV exposure for 4-5 months of the year where I live, so you'll need something even more heavy duty (or expect to replace it even more often) in a climate like FL, etc.
Here is what it looked like before sitting outside:
Here is how it looks after about 5 years of sitting outside:
This is not a concours show car, but it's very presentable and quite comparable to many of the nicest cars you will see at a local cruise night. Hard to keep the engine bay clean though, as dust does blow up from underneath.
I have a lot of cars, more than my current garage can handle so, unfortunately, the '74 has to sit outside. When I move next, this will be corrected.
