Cam choices
Cam choices
Have a ls1 in a 00 trans am with 60k miles that we are starting to build. Funds won't allow heads quite yet but I'd still like to put a cam in it at this time. Car is an a4 with long tubes with catless y, hooker straight through muffler, fast 92mm with nick williams 92mm tb 85mm z06 maf,slp lid, yank ss3600 stall , 3.42 gears. It has the 853 heads and im wanting to run something like the tsp torquer v2. Will a cam that size cause tuning issues or driveablity issues on stock heads?
The CAM will be easy...
The 92mm throttle body will be a good test of your tuning ability.
You WILL of course install the Valve Springs recommended by Texas Speed Products ?
Those "Low-Lift" TORQUE cams, up into the 212/218 duration, .551" WILL start up on a factory tune, and will need minor base running airflow adjustments with the OEM throttle body...
The addition of an after market throttle body changes EVERYTHING.
You say you are having " A Professional" tuner involved, so your golden. Nothing to worry about.
Location: Coast of San Mateo County Between Pacifica & HMB
With a 3600 stall I would look hard at the Cam Motion
LS1 Titan 4 227*/232* 113*+4* .612"/.595"
This will work excellent with your current heads, and
Ported OE, or aftermarket cathedrals when/if you
need/want more.
My .02
need/want more.
My .02
Steves1911 (09-23-2024)
Most cam's in the 23x duration range ideally need, more compression, bigger stall (4000+), 72-7400rpm shift points. For a fun streetcar that retains stock heads, stock compression, with <7000 rpm shift points, I would look at the 228r or something in that realm. Even at that a LS1 still makes great average power with even smaller cams in the low 220 range. It will drive nicer down low and feel more responsive with a cam in the 220-228 range as well. The Nick Williams 92 isn't that bad for tuning. the 102mm stuff is much more of a PITA. jm2c
grubinski (Today)
