LS6/Cathedral to LS3/Square Swap Results
Old Sep 15, 2025 | 08:51 PM
NoGo's Avatar
Default LS6/Cathedral to LS3/Square Swap Results
Back-to-back-ish for a cathedral to square port swap across two very similar setups
Cathedral Setup - PRC 235 CNC port. Cam: 224/231 600/590. LS6 Intake. Ported LS1 TB. LS1 coils
Square Setup - MAST 255 CNC port. Cam: 227/235 640/650. LS3 Intake. 90mm ICON. LS3 coils
Everything else on the blower setup was the same. 21 psi boost and ~16-18 deg of timing, 11:1 A/F. Did a meth-off run to see the before/after.
Top end swap was worth about 67 HP, or about 8% improvement in power. Cathedral made 2% more between 4,500 and 5,500, but notably less above 5,700.
Left the car at 975 HP until I put the stiffer valve springs on and make some adjustments to the meth system - will then be turning it up to 1000+ or so (we'll see).
PRC Head.  LS6 Intake.  LS1 TB.  LS1 Coils
MAST Head.  LS3 Intake.  Icon TB.  LS3 Coils
Old Sep 15, 2025 | 09:02 PM
wannafbody's Avatar
How much do you think was the extra duration of the slightly bigger cam?
Old Sep 15, 2025 | 09:40 PM
NoGo's Avatar
I'm not sure, but I suspect the duration difference isn't doing a lot of work here. Others may have some other insight.
I suspect the lift notably contributed. However, the lift is bigger because the flow sheet of the square port heads. The square ports have a broader flow range at the higher lift. If I left the cathedral cam in on the square ports it would have just been a bad lift range for the head.
Old Sep 16, 2025 | 09:18 AM
slowride's Avatar
Any logs of boost pressure differences? Thanks for the info!
Old Sep 16, 2025 | 09:42 AM
Black_Sunshine_99's Avatar
Very nice!
It's interesting that your boost pressure didn't change, usually it drops a bit when flow is improved.
Boy at 5,700rpm you can really see where the square ports leave the cathedrals in the dust.
What rpm are you shifting at?
Old Sep 16, 2025 | 10:06 AM
NicD's Avatar
7 Second Club
What the heck is going on after 6300 rpms? Is that the beginnings of belt slip or blowing out the spark?
Old Sep 16, 2025 | 10:12 AM
He mentioned needing to change out the valve springs, getting into valve float?
Old Sep 16, 2025 | 10:26 AM
NoGo's Avatar
Pretty sure I'm loosing the valvtrain. Both setups used 160/400 lb in thevalves and I dont think that is cutting it for the 20+ psi of boost. So, similar issue on both setups, but I'll fix it this time around (hopefully).
Old Sep 16, 2025 | 10:54 AM
slowride's Avatar
You might be able to just shim them up if you have the clearance to coil bind
Old Sep 16, 2025 | 11:25 AM
NoGo's Avatar
Graph of boost pressure comparisons between the two dyno runs.
Old Sep 16, 2025 | 11:28 AM
NoGo's Avatar
Agreed. The right shim I think is 0.130/0.140 which shrinks my bind clearance to 0.01-0.02....so I'll probably just get a stiffer spring - and will still need to shim a little.
What opening/seat pressure are folks running for this kind of boost and having good luck?
Old Sep 16, 2025 | 11:31 AM
NoGo's Avatar
Very nice!
I thought that was odd on the boost as well.
I set the limiter to 6,600. Will shift in 6200-ish for now. However, I think once i get the spring issue resolve, I'll get it up to something normal with a 6,500-ish shift point.
Old Sep 16, 2025 | 11:47 AM
slowride's Avatar
Well you want at least 0.050" from coil bind so I don't know if you have that much left or not. I'd try to add 20-30lbs on the seat and test a spring pack to see what you need for shims to get there, it all depends on your spring rate. I'd guess you need about 0.060" shims at least, but best to check over every spring install height apart. It does seem weird that the boost pressure curve tracks with both sets of heads/cam as you would guess the pressure would decay up top on the higher flowing units unless valve float was an issue sooner idk.
Old Sep 16, 2025 | 12:20 PM
NicD's Avatar
7 Second Club
I'm surprised, normally I don't see that type of issue on blower setups even at 20 psi. Hopefully that's all it is though and you can either shim or replace.
Old Sep 16, 2025 | 12:28 PM
I'm using the BTR .660 drop in springs and they are excellent.
21 lbs. of boost and 7,000rpm without issue.
Old Sep 16, 2025 | 12:30 PM
NoGo's Avatar
Me too - I've thrown the kitchen sink at everything else. Blower boost keeps rising consistently (ie. belt seems okay), ignition system upgraded to 510C (and car wasn't blowing chow during run), timing was okay, A/F was a smidge rich but on target.
Also, the boost takes an odd uptick when the torque plummets - and boost higher for the same RPM (in my experience) can be a tell-tale for loosing the valvetrain. Open to other suggestions though - getting this turd to a reliable 1k has been obnoxious.
Old Sep 16, 2025 | 01:55 PM
I'd be looking at the BTR Shaft rocker kit if possible and better springs as you mentioned.
The shaft kit is definitely on my to-do list now.
Old Sep 16, 2025 | 02:20 PM
NicD's Avatar
7 Second Club
Hmm, yeah that is strange with the boost jumping a bit. Does the exhaust note change at all when it happens up top? I normally can hear valve float starting to occur on most combos on the dyno.
I would be measuring installed height and seeing if you can shim them at all, pretty sure 0.060" is the typical safety margin to not go past for coil bind.
Old Sep 16, 2025 | 03:23 PM
NoGo's Avatar
I didnt notice a pitch shift, but the 4" boost activated dump on the exhaust makes it already pitchy and tough to tell.
Looking for a 15% increase in seat pressure - 185 seated, 450 open. I can shim to the seated (0.060 does it), but will need a different spring for the open.
So, in the theme of throwing the kitchen sink, I'll try the stiffer spring first and posibly back to something softer with a shim if it works.
Old Sep 16, 2025 | 07:40 PM
RonSSNova's Avatar
Rectangle port has bigger intake valves right? More valve head area for the boost to fight against possibly?
Valve will be heavier as well.
