"LS7 Lifters" Max RPM's/Lift/CAM Experience
I ran sum brand LS7 Lifters and never had an issue with them at 7,300~7,400 RPM limiters
I have BTR in my daily with no issue.
The only issues I've had were oil pressure related and when I get oil pressure again they pump up fine. So basically have never had a lifter issue
Trying to figure out if I want to build another budget engine or finish a nicer engine. How crazy is it to wring out the "LS7 Lifters" from summit or any other equivalent to 8,000 RPM (probably limiter of 7,600 to 7,800)
Anyone had any experience?
I honestly don't know where to procure genuine LS7 Lifters. I just assume they're all the China reproduction ones. I called a dealer one time and they quoted me 700$ for em.
Know where to get genuine ones for a decent price?
Also I've never had a rocker fail in any form, and I've never done trunions. My buddies did trunions on a LS2 and it had multiple rocker failures within 1,000 miles. So I'm personally not inclined to touch the stock ones until I have a failure
I will definitely do some 8,000 rpm budget stuff on a 300$ engine for science but not for this one.
If I'm being honest with myself I'll probably be fine at 7000~7400 like I have been for years with regular BTR LS7 or the LS7 the guy here sells
Someday I'll do some higher RPM stuff for fun on a cheaper engine
One of the machine shops I've been to in Cleveland let me know Morel was local to him. Said he doesn't like them 🤣
But everyone has an opinion
Yes They do work. Yes they seem to get the job done. Is there something better? Absolutely
That being said, The Cadillac Racing Lifters 88958689 were designed to handle sustained 8000 RPM.
Also it should be noted that GM used Johnson Lifters for the COPO program.
There are many companies that sell "Performance lifters" But very few that will stand behind what they sell. I would talk to any company your considering directly and see what they recommend and why they specifically recommend it. You might be surprised at the answers you get or in some cases what they don't say...
8200+ rpm shift every single pass. Been to 8900 handful of times. Thousands of street miles. No issues. LS7 lifters from BTR, 7 years ago. Still in service.
There is nothing that magically breaks at higher engine speeds. Take care to achieve good valve train geometry and lightweight parts for max longevity.
Question #1 How high can I rev stock and "LS7 Style lifters?"
Answer:
I've personally taken mine to 7,400 many times without issue. Others have gone higher. I called BTR and asked if I could wring them out to 8,000 and they said people do it but it's not recommended. So "safe" internet generally proven is around 7000, people often and frequently go higher without issue of collapsing a lifter or power nosing over
Question #2 Where are all these "LS7 Lifters" coming from?
Answer:
Nobody (not summit, not jegs, not BTR, not Trick Flow) at least to my knowledge has put out a simple video of these lifters coming off their assembly line where they finish grind, inspect, and box their lifters. If they made them or had a "supplier" that was theirs that made them I'm sure they could. If we could buy from their "supplier" directly we would. Why does the boxes all these lifters are in never say what the country of origin is? Alibaba has the same looking lifters on their website...
Let's all just be honest with ourselves
I do not know the guy on LS1TECH supplying these lifters but I'm inclined to believe they all come from the same place in China.
I'm hoping someone can prove me wrong or has some sort of proven relationship with wherever they are made for those of us who do not want to spend 1,000$ on Johnson's for our 4,000$ engine builds
So now that begs the question, do we keep buying summit and mystery brand lifters? Should someone buy some Alibaba ones and take them apart and measure them with mics and put them next to BTR, Summit etc.
Should we keep paying 200~300$ for mystery "LS7 Lifters" or should we just run what came from the junkyard
If one had access to a material analysis lab what are we wanting to see on these?
Having said that, I always use either a Johnson 2116 or a 2126 link bar for my performance builds. Always. $1k is nothing when you’re spending $15-$20k+ on a performance build.
