Toilet paper style oil filter
They were a thing a long time ago when engines didn't have great or any filtration. I've only heard about them on engines from the 50s and back though. Think flathead Ford, etc.
https://www.hagerty.com/media/mainte...y-a-good-idea/
Those were a godsend for engines that didn't have an oil filter already.......back in the wooden-wheel days. Waste of time today. Adding unnecessary joints and seals in a pressurized oiling system is a setup for failure.
What is the goal?
shortened service intervals? the canisters that used a roll of toilet paper for the filter element required 3000 mile oil changes
remote filtration?
the filters were designed for dipper oil systems (like a 1937 Chev stovebolt motor)
as stated above, run a remote filter. if you want better filtration, they make elements that are better that your typical COTS oil filters. many of the remote mount diesel filters will filter down to 2 microns
remote filtration?
A giant techonological leap backward into the nostalgic 1940- 1950's period of dealer or customer installed OPTIONAL oil filters, on rudimentary, cheap OEM cars and trucks, built and sold with NO FACTORY OIL FILTER. Yep, no ****. Brand new 1950 chevy had NO FACTORY FILTER. oil change intervals were typical at 1000 miles.
DIY would add a bypass oil filter, that ran a small fraction off the pressure feed oil galley- THROUGH a cellulose media filter, looked like a low grade roll of toilet paper, and the "Filtered" oil returned directly to the oil pan. Bearings were fed direct UNFILTERED oil from the oil pump. "The Good Old Days "
Adding such a throwback to a modern fuel injected, FULL FLOW FILTERed oiling system is idiotic
