Mixed Info About Pushrod Clearance - am I too close?
Old Apr 28, 2026 | 12:05 PM
OtakuFather's Avatar
Default Mixed Info About Pushrod Clearance - am I too close?
Hey all -
So I have perused this forum and others online and I want to be sure, before I button this engine up and install here in the next few months that I am not making a mistake. I bought and installed thicker pushrods, but the clearance is very tight. Below are some details and images to help with opinions.
Info:
  • Full engine rebuild, bottom-end just back from machine shop, I put together top-end - fully upgraded rockers (better trunnions), new single springs, valve stems, valves etc.
  • Mild cam installed - duration @0.050 I/E 220/222 | Intake center line 110 | Lobe separation angle | Rocker ratio 1.7 | Valve lift (in.) 0.570 / 0.570
I elected to go with a sturdier pushrod, but fear I may have gone 1 step too large. Pushrods are 3/8 diameter w/0.080 wall. The motor is on a stand now, so if I have to swap out with a thinner pushrod, I have time, but want to be sure before I gear up to install the motor. Let me know thoughts, thanks in advance all!
See pics below, let me know what you think.
Basically touching
Basically touching
Gap on far side
Gap on far side
Basically touching
Basically touching
Old Apr 28, 2026 | 12:52 PM
RB04Av's Avatar
Yeah that looks a bit close.
Might want to drill those out a bit. Or swap to a better-fitting PR.
Old Apr 28, 2026 | 02:49 PM
LilJayV10's Avatar
I think I would go with a 5/16 or 11/32. I don't think you are running enough spring pressure for there to be a difference. Just my 02.
Old Apr 28, 2026 | 07:09 PM
Pushrod will flex at rpm, and need a larger hole. 11/32” is what you want to run there. You can always sell the 3/8” rods to make a little coin back.
Old Apr 29, 2026 | 08:43 AM
Thank you sir - I will go this route instead. Appreciate the help!
