Ford injectors on LS1
Old Yesterday | 07:54 PM
sycl956's Avatar
Default Ford injectors on LS1
We Put these injectors that were marked as denso from TSP they fit good and no leaks but was told the spray pattern will cause issues as it’s for a DOHC intake I believe these injectors are from a 2012 6.2 f150 the nozzle had 6 holes while the stock ls1 look alot simpler
car runs rough and only works somewhat decent when warmed up
fuel pressure is at 58
cammed torquerv2
Old Today | 04:20 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Did you find and use GM formatted data to retune for these injectors? If not, it will never run properly.
