Since it’s your first rodeo here, make sure your main cap orientation is correct….they are all in the correct spot…#1 is front and #5 is rear. Make sure they are turned the correct direction. If you didn’t mark them to indicate forward direction, then you might have one or two…or more facing the wrong direction which will affect tunnel alignment greatly. This is easy to do as a novice, trust me. Also as mentioned by RD, your bearing clearances must be checked in this situation, to eliminate possibilities. As a builder I’ll suggest to you that you make very sure that everything is clean, and then wash it again….and again. You can’t get everything clean enough. Make sure the backs of your bearings are dry. Bearings are a press fit. The only thing keeping them from spinning in the bores is their press fit. Oil behind them is bad. Your main bolts torque in a sequence. You can find the sequence on many websites…look it up. That’s important here also. Hit us back with any more questions.
…edit…and because the ARP main fasteners have more clamping force, they do have the possibility of distorting your main caps. I’ve posted pics here many times of a line hone after ARP main stud installs, to illustrate just how much the caps and block distorts. I didn’t want you to think I was overriding what RD mentioned about distortion here…I was simply throwing out things to try before you have to take it to a shop. I DO a see guys installing ARP main studs and not having to line hone, but it’s few and far between.
