Accessories for LS swapped 67 Firebird
Old May 11, 2026 | 01:56 PM
jrpimp00's Avatar
Default Accessories for LS swapped 67 Firebird
I know that Holley is King for this stuff, but are there any other options out there for a seamless swap? Holley comes with a hefty price tag for what this is. I am putting a LS1 into my 67 and will be keeping AC and power stearing. Im sure a mid mount or high mount setup will work but if not, please explain. If I can run OE accessories, NOT TRUCK, then what is the best option to achieve this goal?
Old May 11, 2026 | 03:07 PM
LS1 TJ's Avatar
Don't know if it fits for your 67 but I like and use 2002 Camaro FEA stuff on over half dozen LS swaps. ICT makes the FEA mounts/brackets. Some OEM brackets are still available. Stock components like the PS pump, alt and water pump can be purchased at NAPA and come with a warranty.
Old May 11, 2026 | 03:26 PM
Scott Danforth's Avatar
What is the motor out of? grab F-body or Corvette belt drive and accessories
Old May 11, 2026 | 06:13 PM
jrpimp00's Avatar
Motor is out of 98 Trans AM. I am concerned about the low mount AC and alternator hitting the cross member in the 67, at least that is what I am finding online. Wont be pulling the SBC out for a couple weeks, so cant verify in person yet. Everything I find says, I will need to get mid or hight mount options or modify that crossmember significantly.
Old May 11, 2026 | 08:01 PM
LS1 TJ's Avatar
Most that want to keep the low mount ac comp will have to notch the subframe on the right side. Not a big deal. Can't speak to the alt.
Old May 11, 2026 | 09:21 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have the engine set back an inch in my '67 and truck spacing with a 5th gen water pump.
