LS3 - MAF Frequency Fail High Setting
Old May 31, 2026 | 01:35 PM
lep's Avatar
lep
Default LS3 - MAF Frequency Fail High Setting
My new LS3 (700 miles on it) is swapped into a rear engine vintage Porsche. This morning after a good startup and long cruise, I stopped and went into an auto parts store. When I came out and re-started the engine, the idle entered into a cyclical loop (sine wave) and the throttle was unresponsive. After several wait-and-restarts, idle resumed normal procedures. When I got home, I ran a scan and detected a P0103 DTC, which meant that the MAF sensor triggered an error. Cause --> With wrapped headers, and running a higher than normal IAT (I don't have cold air intake), as soon as the engine stopped and there was no air movement, heat rose and caused a heat sink on the MAF - so at startup the ECM threw a P0103.
Right now, the MAF Frequency Fail High is set to 0 Hz. Can I set it to e.g. 14000 Hz, which is above the max Hz I'll ever see?
Old May 31, 2026 | 02:04 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
You need to post the tune, but if the MAF fail high frequency is set to 0, you are not using the MAF at all. Your problem likely lies elsewhere, and may be tune or mechanical related.
Old Jun 1, 2026 | 01:54 PM
lep's Avatar
lep
This is a rear-engine swap - so airflow in the engine bay is not like airflow in a front-engine swap --> a much hotter environment.
FYI - I just noticed in earlier tune files, when I didn't experience limp mode when re-starting after heat sink, that the MAF Frequency Fail High was 14,500 Hz.
Here's the tune file. The cycling idle RPM (like a sine wave, 1000-1500) occurred again yesterday after a long cruise, shut down, then restart 10 minutes later. I think it's called limp mode caused by heat sink, which can occur after brief shut down when hot, and then attempting restart maybe 10-30 minutes later. During restart and heat sink, all the hot air from the block, headers, transmission rises to the intake and MAF sensor. Sucking in that hot intake air at startup causes the ECM test to fail - since several parameters don't correlate.
I know there is a test conducted at startup at 1.0 seconds to check for the MAF sensor and IAT, so is the solution to delay that to 3 or 4 seconds, when cooler air is sucked in?
File Type: hpt
Old Jun 1, 2026 | 03:47 PM
gametech's Avatar
Just run the MAF fail frequency back up to what it was previously set for, and see if the problem returns.
Old Jun 1, 2026 | 05:10 PM
lep's Avatar
lep
Thanks, that's what I planned on doing - since I know I never went into limp mode or threw P0103 DTCs during very hot starts with the previous tune files.
Old Jun 1, 2026 | 05:41 PM
grubinski's Avatar
I’m old, but mostly don’t feel old, until someone describes a ‘70s-‘80s Porsche as vintage. *Then* I feel old. Thanks. 🤣🤣🤣
Old Jun 2, 2026 | 10:59 AM
NicD's Avatar
7 Second Club
First I would ask your tuner why they decided to switch to speed density from the MAF, they may have had a very good reason to do so and I wouldn't just go making changes. Looking at the tune file it certainly looks intentional on the switch to SD. However they missed a few things that need to be done if they are running it in speed density on this computer, like the Speed Density Air Mode patch. Also, when it goes into limp mode it's likely to throw a code which will give you more information on why.
