Scavenger pump ideas
Make sure the drain plate gasket is not leaking, usually when the shaft seals leak the oil comes out the exhaust or out of the mounting flange of the compressor.
As long as the drain has vertical slope and is of sufficient size, you shouldn't need a scavenge pump.
Also make sure your engine crankcase is able to breathe sufficiently because that will affect turbo draining.
If your set on the pump, mount the pump close to the turbo, the turbo drain can go straight to the pump although having the turbo drain into a small tank mounted right under the turbo and then having the pump pull from the tank is highly recommended.
No harm in using one, just one more failure point is all.
The other thing you could do is add an oil pressure regulator for the turbo, Turbosmart makes one.
Here's a pic of the tank if you end up needing to go that route. The tank ensures the oil clears the turbo cartridge and then the pump pulls from this.
I'd use a regulator first, something like this.
OPR V2 Turbo Oil Pressure Regulator – Turbosmart USA
