Sponsored by: CARiD
97 Trans Am loose ignition cylinder issue
Old Today | 04:29 AM
reservoirdogs12's Avatar
Default 97 Trans Am loose ignition cylinder issue
So I replaced the turn signal switch last weekend and now my key moves freely back and forth in the ignition cylinder and doesn't do anything unless I hold the steering wheel at a certain angle. At that angle it starts and shuts off the car every time. There is an incredible amount of play in the steering wheel up and down and I
definitely know some bearing or pins are warped. Time for a new steering column? New pins? Should I attempt this repair myself? Is there something I can do below the turn signal switch to remedy this?
