2002 Pontiac Trans Am Firebird WS6 Convertible "Last Of The Breed"
Regarding the LOB (Last of Breed) badges, these were available from multiple sources back in the day and could've been either dealer- or owner-installed. I don't think these were installed at the factory. I've seen them on MYs other than 2002, FWIW. These badges don't really contribute to a car's rarity.
Regarding you car's rarity, CompNine's database (**) indicates a total of 229 2002 WS6 'verts had the Z49 Canadian Export RPO, 114 w/ M6 and 115 w/ A4. Consideing your car is 81U Bright Red, it is highly unlikey it is the only red '02 WS6 'vert exported to Canada. You may be able to confirm it's actual rarity (1 of X) by checking your VIN at CompNine.com and filtering on only the RPOs WS6, 81U, MX0 and whatever RPO code is associated with your interior color (warning, if you use all of your car's RPO codes, nearly every car becomes a 1 of 1). User 98_1LE may also be able to assist, and may be able to provide you with the ASC conversion number based on your VIN. Good luck and enjoy your beautiful WS6 'vert.
(**) Edit: CompNine's database appears to be missing a sizeable chunk of production in the '02 MY Firebirds. They report that there was a total of 1629 WS6 'verts built in 2002 while another source indicates that number is 2696. So the numbers quoted above are most likely low. Since CompNine's database had much more filterable detail than the other source, I used it for generating my breakdowns, flaws and all.
