metric A/C expansion valve fittings
The good news is I can replace the evaporator to match a later fbody, but that is spending 6 hours taking apart the dash and having done that a few times, it's a lot of work. Ideally I can buy the adapters somewhere. My goal is to run all LS components with the custom hose fittings tot he evaporator I have stock. any suggestions on fittings? Cold hose told me they don't have the Metric Oring fittings.
M27 to #10 hose
https://coldhose.com/products/12-27m...42825998762239
M20 to #8 hose
https://coldhose.com/products/8-90-d...35531735793824
The search feature is excellent on their site. Simply searching "M22" found a multiple fittings
If those don't work, you may be forced to cut/weld. Typically, male fittings are limited to the end device, so are rare to get as loose fittings
93-95 3.4L V6 Fbodys used this style hose and had a unique evaporator core to match. Everything else is a standard metric fitting or GM bolt on block
For this, you're going to be forced to cut/weld or change the evap core
