MS3 Track times
Old Apr 16, 2006 | 11:15 AM
HottLS1Z's Avatar
Smile MS3 Track times
Well as some of you know I was B*tching before cause my MS3 cam only put down 362 RWHP, ell here is the track results. Whats some opinions?
I went to the track yestrerday and with NO suspension mods what so ever not even control arms on an ALL SEASON Kumo tire (275-35-18) on a Z-06 wheel here was my best run with currently 273's. all passes were within a half a tenth of each other.
60'...1.728
330...4.980
1/8...7.712
mph...89.89
1000...10.062
1/4...12.062
mph...112.32
That 60' time is on the previously mentioned tire no weight reduction and completly stock suspension with the exception of a strut tower brace. what does every body think about gearing? I have 10's or 342's collecting dust. one set will go in this next weekend if I decide to still ditch the 273's. I still think 1.7 60' is amazing on street tires and a 2200 launch. (Just for amusing bragging rights I had the fastest streety car at the test and tune all day!) the cobra boys were not happy about this.
Old Apr 16, 2006 | 11:33 AM
radz's Avatar
Thats pretty good bro. I'd be happy I see 11's in your future with supension.
2000Hawk's Avatar
I think that looks real good, i mean with no suspension mods a 1.7 60' any day is real good. And your times look real good as well, no complaints here congrats.
Old Apr 16, 2006 | 11:46 AM
DevonsZ's Avatar
Congrats on those times, you should see some 11's with those traps id think. Do you run at Gateway?
Old Apr 16, 2006 | 11:56 AM
EXILE's Avatar
MS3 needs steeper gears like 373 or 410s and a big stall, i have 373s in mine and running a tighter stall for n2o
Old Apr 16, 2006 | 11:59 AM
Quik's Avatar
now why is that cam only putting out about 360 with bolt ons? a buddy just dynod his and got the same numbers
Old Apr 16, 2006 | 01:04 PM
92zcamaroperson's Avatar
auto+stall....numbers would be higher with a manual. But as you can see dyno doesnt always determine everything.
Old Apr 16, 2006 | 01:48 PM
HottLS1Z's Avatar
Interesting..I thought I ight have just had a shitty dyno..Using another calculator a guy I
Know did some estimates and those times are good for 490-520 flyheel hp and 390-420
RWHP depending on driveline loss based on the cars weight (3650 with me in it) and the ET's and speeds and times.
Old Apr 16, 2006 | 01:54 PM
HottLS1Z's Avatar
Never heard of it. I went to Route 66, I also going to US 41 Dragway in IN and will probably hit up Byron in Rockford IL this year cause from 9:30-4:00 I only got 4 runs in at 66 because of how packed it alays is. Its just nice and close to me (15-20 in ride).
Old Apr 16, 2006 | 02:03 PM
Quik's Avatar
yea buddy just ran a 12.2 at 110 with something like 1.67
hes 342 geard,4k stall, stock supsension with spool torque arm, MT DRs,LS6 intake,TSP tune
last year with same setup and a different in house tune done by streetnstrip he ran 12.0 at 112 i believe.
his dyno numbers were from 2weeks ago
its odd a combo like this would run slower with a TSP tune then a in house tune from SNS
Old Apr 16, 2006 | 06:24 PM
HottLS1Z's Avatar
well with 410's ported TB,Pully, and 90/10 struts, LCA's and frame connectors 1150's is coming.
I only launched at 2400 also with DR's Ill go 3500 Lanch!
Old Apr 16, 2006 | 06:29 PM
REDWS6ROCKET's Avatar
i can't wait to get mine to the track this week, it runs awesome on the street. should go deep in the 11's as long as i get it to hook!
Old Apr 16, 2006 | 09:46 PM
HottLS1Z's Avatar
anyone else have any input
Old Apr 16, 2006 | 10:30 PM
HottLS1Z's Avatar
...ttt...
Old Apr 16, 2006 | 11:06 PM
Psycho Dave's Avatar
I was looking at this cam also but that et/mph is bolt on only territory. I wonder why they are lacking hp and running so slow? I dont understand why there are so many differences between cars on here with pretty much the same parts....
I understand there are a lot of guys that lighten their cars up pretty good and run some great number and dont make much mention of weight and then the slower guys wonder whats wrong with their cars....No matter what I would expect more mph out of that cam. It cant be just luck, why do some cars run .5 second quicker than others with the same mods????
Old Apr 16, 2006 | 11:12 PM
steveb's Avatar
DRIVER
Old Apr 17, 2006 | 05:29 AM
Jake the SSnake's Avatar
Originally Posted by steveb
DRIVER
I don't think so in this case... 1.72 60ft is EXCELLENT for a 2.73 car on all season radials,stock weight,and a "smaller stall".In this case the mph just doesn't look right.I run 7.80's in the 1/8 @88 mph all day long with just boltons.Of course the ms3 needs a bigger stall and the et's would improve w/some weight reduction and deeper gears.But I think it should be trapping about 4-5 mph more than it is.How is the tune on this?
Old Apr 17, 2006 | 05:38 AM
VORTECFCAR's Avatar
With those gears you're probably going through the traps in third gear at about ~4600 RPM (help me here), whereas a guy with 4.10s is seeing significantly higher RPM. A dyno sheet will show you that the car is making quite a bit more HP (read MPH) at higher RPM.
Long story short: I believe not only your ET, but also your MPH is suffering due to your gear.
~Nick
Old Apr 18, 2006 | 07:32 PM
HottLS1Z's Avatar
Well the 410's and frame connecters&LCA's go on next week so Ill post the results. Any guesses?
Old Apr 18, 2006 | 07:42 PM
Robinator's Avatar
I would say......better......
