'99 Z X-pipe
Old Nov 28, 2006 | 11:14 AM
SSnemesis's Avatar
Default '99 Z X-pipe
Does anyone know if an X-pipe fitted for a '99 Z-28 fits on a '02 SS? If he is running hooker headers would I have to run the same type of header? I am thinking about buying it off a friend
Old Nov 28, 2006 | 12:26 PM
TheBlurLS1's Avatar
That's what she said...
It should fit, having Hooker headers will make it incredibly easy, but most of these headers come out in about the same spot. May want to have some cutting/welding tools handy or hav a shop install it on your car.
Old Nov 28, 2006 | 01:12 PM
lsx24's Avatar
What headers are you running (on the 99)? What xpipe is your friend running? Is it a system or custom?
There's really no difference between a 99 and 02 as far as you're concerned it's all about what header you are running, and they're all pretty close. A muffler shop should be able to make it fit no problem like mentioned above so you should be good to go.
Old Nov 28, 2006 | 01:48 PM
SSnemesis's Avatar
thanks for the feed back. . . .the '99 is running hooker headers and an x-pipe with twista mufflers. As far as the '02 is concerned its stilll bone stock and I am just now starting to do mods on it. I was wanting to go with a good set of pacesetter headers.
Old Nov 28, 2006 | 02:03 PM
lsx24's Avatar
In that case if it's stock you would need to extend the end part of the X pipe to fit stock manifolds, but if you are going to be running Pacesetters they will most likely just line up fairly close.
Old Nov 28, 2006 | 02:23 PM
SSnemesis's Avatar
thanks yeah I am going to just do the whole setup X-pipe and headers and get rid of that annoying air vacumm that comes up the side into the lid
Old Dec 7, 2006 | 04:44 PM
A-Bomb's Avatar
i'll be delivering your x-pipe next week.
