Lots Of Parts Left
Weld Magnum 15x3.5 Front wheel- $475 SOLD
LS1 Edit Model Year 2000- $250
Performaire o2 Weather Station- $350
Hooker LT Coated headers- $425 SOLD
Schubeck Lifters- $165
SLP Double Roller Timing set- $95
Comp Cams Hardened pushrods 7.35"- $50
JPR Electric water pump- as far as I know this may be the only one in this version. Its the tubular version, CSI remote water pump. You will need to get some braided line and fittings to be able to install this- $250
4L60e- Stock with deep truck pan, 4500 miles need to replace drain plug- Will NOT Ship this, Will meet you- $275
Oil Pan Corvette- $90
LS1 2000 Block- $200 WILL NOT SHIP
Stock front hubs w/ Longer stock studs- $65
Stock Crank- $85
ABS Module- $140
Stock Front engine cover - $25
LS1 Stock Valley cover - $25
MSD plug wires- $50
Stock Aluminum Driveshaft with Auto Yoke- $100 PENDING
Coil Packs- $110 SOLD
Poly Torque Arm Bushing- $12 PENDING
Poly Trans Mount- $25
Yank Thruster Pro 4500 Converter- $550
Engine Pedestals- $30
I think this is it. Also once the items are paid for it won't be until the weekend before I'll be able to ship the items out.
http://rides.webshots.com/photo/1398...lM?vhost=rides
The other wheel has never been out of the box
LAter
