Polishing your aluminum? STOP! Best polish ever inside.
I've used Mothers liquid power metal on the powerball, used the Adams 2-step metal polish, used the Mothers mag and aluminum polish, and probably a few others.
The stuff must be oil based or something. It just rolls right off the metal if you drip it directly on the wheel, very strange consistancy. It's not an abrasive, more of a chemical-cut on the metal, but it doesn't have much of a noticeable smell. It's very easy to use, and you can see the results coming thorugh within the first few swipes. You don't have to wear your arm out with it, just make sure you get a nice coverage.
After they were polished up nice, I used the Master Formula Sealer Gloss. This goes on very easily and looks like water after you rub it around a bit. It will dry to the surface like a wax and is easily removed. After this treatment, the wheels have a little more shine, but are much more slick feeling.
I applied the polish/sealer with pads from Adams Microfiber Applicator Pads, and removed it with standard microfiber towels. Once the pad would become nice and saturated/black with the polish it would really start working good. At this point a little would go a long way.
Here's the pics, and as always, they don't do them justice. If this polish can make my fubar'd wheels look this good, imagine what it will do to a nice set.
BTW - Here's a link to the polish..... http://master-formula.com/english.htm
......... i just found me a new quoteLast edited by Jeremiah; Apr 18, 2007 at 09:15 PM.
Then for the next month I can keep 90% of the shine by wiping it with warm water.
I need to polish once PERFECT and then clearcoat. Do they make clearcoat that can adhear to straight metal?
WOW! Must be good stuff. I'm gonna go ahead and try it, ur pics convinced me!
