95Z28 Rolling Chassis - A ton of aftermarket stuff!
Let me breakdown what it has currently:
body (of course) - worth around ~$1500
New Moser 9" rear powdercoated black (Detroit locker, 3.55's, 31 spline, 1/2" studs)- $2300
Rear Spohn tubular control arms (powdercoatedblack) and rear adj. pan hard rod: $350
Front tubular BMR k-member, tubular upper and lower control arms (all pc'd black): $900
ZR1 corvette front breaks (dual piston PBR calipers, 13.2" Baer rotors, modified spindles, new hub assemblies) - $1000
alky control meth kit (components pieced together) - $400
Dual gauge pod with elect. fuel pressure gauge and vacuum/boost gauge + shift light ($350)
electric fan switch to manually control the fans ($45)
Fuel - Dual walbro 255 intank pumps, 8AN feed line, 12" long Barry grant fuel filter, 8AN to to a y-block that connects to mofified fuel rails, 6AN return to an aeromotive (or Holley?) regulator, 6AN return to the tank) - $1000
SLP linelock - $130
Hal12 way Adj shocks and Eibach sportlines - $700
Thats $8675 in parts, no labor. The car is setup right. I am sure I am forgetting other goodies. I am looking to get $7300.
$7300 + your engine and tranny combo = a seriosuly setup vehicle.
The enginebay was just resprayed by my buddy. Its not perfect, but looks great.
Alot of the stuff is just dirty/dusty... the parts will clean up nice though. If you want to talk about it or see it in person thats fine.
The car is in disarray. The front clip is off due to mounting an intecooler. There is no exhaust currently on the car... I could throw in a flowmaster catback. I am willing to start putting some of it back together if I had a sale.
The fuel system is not wired up yet (wiring is there, just not hooked up to anything).
Steering rack is there, lines all disconnected. Brake lines are there, just disconnected. I bough Earl flexible lines for the front/rear I was going to put in.
The buyer would need to bring rims/tires in order to make this a roling chassis. Pickup only.
Jon
