FS: RPM Stage 5 4L60E and Yank SS3600
I'm in the process of converting my car to a 6 speed so, I don't need this anymore. The trans is an RPM stage 5 4L60E. This is coming out of my Formula and has about 4000 miles on all parts. Everything works flawlessly.
Here is the write up of parts that are in the trans from RPM:
Media blast transmission case
RPM sleeved input drum
RPM 3-4 clutch pack
RPM sunshell with laser welded collar and bearing
Heavy Duty double caged 29 element sprag
4L65E low roller clutch
Billet 4th gear servo
Transgo HD-2 shift kit
Corvette Servo
Wide 2-4 band
Updated aluminum accumulator piston
Bushing kit
new shift solenoids
new GM valve body spacer plate
GM 5 pinion planetary gearsets - front and rear
Seal & gasket kit
Filter
Set end play to our specifications
I'm asking $1800 for the trans. The trans will include an Autometer Trans temp gauge since the pan has been tapped for the sensor.
The converter is a Yank SS3600. It also has about 4000 miles on it and was installed at the same times as the trans. I'm asking $450 for this.
All prices are plus shipping. I would be willing to meet someone half way if they are close enough.
I also have parts to convert your car to an A4. PM with what you need.
RPM 3-4 clutch pack
Corvette Servo
Wide 2-4 band
Bushing kit
new shift solenoids
Seal & gasket kit
Filter
