Fast 90/90 beneficial when running a reverse split cam like the X1?
The best/correct response above was the shortest one. The source surprised me, however.
As has been mentioned, the RS cam is taking you the wrong way and you want to compound the problem. The logic of increasing the intake flow with a restricted exhaust duration and lift and then greatly increasing the needed exhaust flow with a 100 shot while keeping the same short exhuast duration/lift completely escapes me. I suspect your engine won't be too happy with that either.
If you mind really is open, get a decent cam designer to do a cam for the combination you finally settle on. Sell your $400 cam on ebay to someone who believes in reverse splits for LS1 engines. You should be able to get a c-note for it.
You won't find the right cam guys posting here, BTW. The have either been banned or exited stage left of their own accord. More's the pity for the folks still here.
Larry
Ron, what are your technical views on the OP's Reverse Split cam for his application?
I have never personally seen a reverse split work in an LS engine. I would never suggest a reverse split to anyone with an LS engine, more importantly to someone wanting to add nitrous. I have already discussed cam options with the OP and told him to get the X1 out of his engine.
I have my own thoughts on all of these "custom cam" designers as of late, but Ill keep that to myself
I found EC without a link. Thanks anyway.
Your thoughts on "custom cam" designers would be interesting to many, I'm sure. They probably don't all use XE-R and/or Xtreme RPM Hi lift lobes, but some might. Some don't say, some do.
Jon
