Could this be enough to squeak me into the 9's?
Hey guys, I'm just curious if you think this setup would be enough to squeak me into the 9's on a dedicated drag wheel/tire combo?
I'm currently running just a set of M/T ET Street R's, so I doubt that's going to get me there. Also, what do you guys estimate traps will be? Don't know DA, am located in central IL, so we can get decent DA during the cooler months around here.
02 WS6
45k miles
BTR Stage 4
TFS 220 ported by Tooley
FAST 102 also ported by Tooley
FLT Level IV Trans
Circle D 5C (4-4200)
MWC Rear/Suspension 3.89
Racetronix 255/hotwire
36 LB injectors.
Nitrous Outlet hardline kit, going to spray 150
Probably going to be about 3600 lb raceweight
02 WS6
45k miles
BTR Stage 4
FLT Level IV Trans
36 LB injectors.
On a stock LQ4 with a smaller cam (228/232 .600/.600" 112+2), 243's, FAST 92 and 200 shot on Nitrous Outlet Plate system at 3650lbs with me in the car and a 4l60e with 3500 stall converter I went 10.28 at Atco in NJ. This was a couple of years ago.
02 WS6
45k miles
BTR Stage 4
FLT Level IV Trans
36 LB injectors.
02 WS6
45k miles
BTR Stage 4
FLT Level IV Trans
36 LB injectors.
