2 tons of cookie cutter car + 16# of Chinese turbo = 9.94@138
2000 WS6 Trans Am, 6.0, 4L80E w/3000 stall triple disc converter, 9" Trick Chassis rear w/370 gears, 275/60R15 ET Street R's, old *** Trick Flow heads, "Sloppy" Stage 2 Elgin cam, Dorman LS2 intake, 92mm throttle body, 1000cc Snake Eater injectors, HPTuner street tuned (on E-70) by me. Weighs 4,060 with me in it.
Just before Christmas of 2019, I swapped on an ON3 A/C delete turbo kit. Mistake not getting the 78/75 optional turbo from the start, but the stock 70/65 turbo was still pretty impressive to me. Bought a used VS Racing 78/75 cast turbo, and new AEM dual 340lph pumps, -8 feed, -6 return, Holley rails.
First actual Test & Tune was May 30, 2020
1st pass, left from an idle, on no boost/footbraked, boost on wastegate (4-5#) and went 11.47@127
2nd pass, left at just shy of 4#, on 13.5# boost, and went 10.34@135
3rd pass, decided I was going to not worry about the lights, turned boost up to 15-16#, and try to make a good pass...
Went 9.94@138, then hotlapped to a 10.02@137
Have since swapped on a VS Racing Next Gen Billet 78/75, which definitely spools quicker than the cast one.
I also swapped to a chrs1313 dual 450lph pump setup
Pretty sure in cool weather, the car will go mid 9's pretty easily...but time will tell.
In-Car potato camera 10.02 run below...Camera phone didn't record the 9.94 run...was overheated, lol.
The following users liked this post:
rel3rd (06-26-2020)
