LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Single Digit Club (https://ls1tech.com/forums/single-digit-club-89/)
-   -   How much power for 8.99's? (https://ls1tech.com/forums/single-digit-club/579295-how-much-power-8-99s.html)
TurboGoat Sep 20, 2006 06:25 PM
On a nearly 4000lb car?
Will a GT76 with a built motor and of course all the supporting mods get me there?
qqwqeqwrqwqtq Sep 20, 2006 08:55 PM
I doubt you could accomplish those times with a 76mm turbo and 4k lb raceweight.
My best guess is that you would need around 1,000rwhp, which you could accomplish with a single 88 or twin 61's. (and obviously there are a million other variables).
skipperbisket Sep 20, 2006 10:29 PM
the 4000# raceweight is going to make it a pita...
Scott@DrivelineSolutions Sep 20, 2006 11:12 PM
I am 3305 with me in mine 3rd gen and I just broke into the 8's. I figure I am making 850 RWHP and 1000 FWHP.
mrdragster1970 Sep 22, 2006 08:41 PM
1000 + for sure
EATON22 Sep 26, 2006 11:34 PM
Hey,
I have a 3300 lb. 88 Mustang Hatch back with a 331 C.I. and a 76 mm Turbo with a Turbo 400 and on just 15PSI making only 575 RWHP have ran a 1/8th mile best of 6:30 which computes to 9.7 in quarter. With a larger engine and 24 PSI or more I would be surprised if you couldn't hit the high 9's LOL
TchargedLS1TA Sep 28, 2006 04:12 PM
I'm thinking about 1300 flywheel horsepower, or roughly 1000-1100 rwhp..
Definately wont be done with a 76mm turbo.. You'll need a 88mm at the least, and I would even run a 91mm just to keep your turbo from surging..
RedHatRdRacer Sep 29, 2006 08:17 PM
Well I have been some 6.2 and 6.3 but no 9.7
Originally Posted by EATON22
Hey,
THE_SUPRA Sep 29, 2006 08:23 PM
how is your chassis set up? that can change things big time!
trouse40 Sep 30, 2006 02:39 PM
a 76mm turbo wont support 1000hp?
TchargedLS1TA Sep 30, 2006 04:34 PM
Not without surging or running the turbo at its limits....
427 Oct 1, 2006 09:22 AM
I don't normally run the dyno much then go to the track, but I did getting ready for drag week.
Car is 72 Nova weighs 3815 with me in it.
Ran the car on our Mustang chassis dyno to verify it was ready to race, it made 711 at the tire with the drag week pulleys on it. SC 402 LS2 based engine. Drove off dyno and into trailer, off to Cordova. Off trailer into tech then staging lanes. First ET was 9.27@148mph leaving off brake at 4500rpm. Second run moved two-step up to 5500rpm, spun tires. Third run lowered two step down to 5000rpm, just lightly rattled the tires on launch, ET 9.29@148mph.
Kurt
Pro Stock John Oct 1, 2006 09:53 AM
Thanks for sharing Kurt!
SSilverSSurfer Oct 2, 2006 12:22 AM
Kurt
i saw your car in hot rod magazine, looks like a sleeper :devil: :drive: :hail:
04gtoBMXracer Oct 2, 2006 12:38 AM
Yeah I saw it in hot rod too BADASS!!!!!!!
Justa Z Oct 3, 2006 04:17 PM
I hope to do it with right around 800rwhp next summer :)
© 2026 MH Sub I, LLC dba Internet Brands
