is this setup capable of getting close to the 9's???????? what should i get out of a setup like this.the guy that has it say's it runs a 6.49 1/8 mph unknown. think it will in a stock weight 98 ta.it is supposed to make 425rwhp motor 630 on the juice so it works out to be a 200 shot. Patriot 59cc Ls6 Heads TSP Hardend Pushrods Ls6 Ported Oil Pump TSP 231/237 on 114 ARP Headbolts and Rodbolts Cometic Head Gaskets Ls6 intake Timing Master Heavy Duty Timing Chain BBK 80mm TB QTP 1 3/4 Ceramic Coated Headers 2 Stages of Nitrous (about a 200 shot) Built Turbo 350 Manual Valve Body 3000 Stall converter New 3.73's in the rear |
I could be wrong, but i dont think that will cut it on a full weight TA... |
low 10's maybe ???? |
Again I’m not the person to trust (certainly not the most knowledgeable person on here) so please take this with a grain of salt, but yes I would say it should be good for low 10's, but I don’t think its enough to break 9's. Good luck with the setup, its sounds like a good proven one. |
i'm just trying to figure out if it will run what he sed it runs a 6.49 1/8. i think it should because there are cam only cars in the really high 6's. |
im sure it will do that in the 1/8 mile |
anyone else.help and comments are appreciated. |
a little more stall, a little less weight and you should be there. |
Originally Posted by kngkahious i'm just trying to figure out if it will run what he sed it runs a 6.49 1/8. i think it should because there are cam only cars in the really high 6's. Need to keep it to one trend, BUT I'll answer this one. Look at their weights. Most running those numerous are at 3100+/-. NOT at your 3500-3600 lbs. Same answer otherwise as on other trend. I doubt you'll see 9's even on a 200 shot, maybe mid-10's if you don't bust your stock rear-end. David |
thats cool i just need someone to break it down. |
stock bottom end??? if so hope he has upgraded rod bolts as he is already pushing it with that 200 shot. but honestly i dont see 9's from it |
| All times are GMT -5. The time now is 03:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
