305 sbc...
A 305 Chevy has enough potential to make for a pretty nasty street engine. You need to have a pretty decent knowledge of automotive engines to realize that. You obviously don't. It's not the best, baddest, most efficient, whatever, but it's certainly not a boat anchor. Ignorance is ignoring.
and i built a 423hp 305 n/a a few years back, and it went faster than every one of Zones builds to date if i remember correctly
give him a day with 2 different cubic inch motors, and he will have the lesser motor making the same power as the larger motor.
case in point, tommy brewer ran limited street in his SVO with only a 363 inch motor and an f3, and was spanking guys running 4-500 inch boosted motors.
thanks for the link to this thread, btw. its quite entertaining.
Just about everyone makes pistons for a stock stroke 305, but no one makes a stroker piston. I can understand, as it is probably not common, but I don't think it'd be too much to get some done.
EDIT: I gave this info out in another thread that we bolth replied to.
Come on, tell me the 305 can make as much as a 400 SBC? Or a bigger motor, i am still waiting.
How much do they usually run? Around $500-600 or so?
You have this narrow minded thought process that tells you small bore = bad! You probably still think you can see a engine's A/F ratio with EGT's! That was a common misconception rampant 20-30 years ago, and it still is today, even though there are tremendous volumes of information out there to prove otherwise. Remeber what I said, "reason may mislead us."
IT CAN! Look at the 360ci NMRA Hot Street motors. They're making well over 800hp on the engine dyno. That's close to double that of what your average 400+ci motors make, and even more than a lot of 470-500ci Big Blocks. I said this before, and I'll say it again...it all depends.
Heads must maintain stock valve sizes and runner VOLUMES...BUT the use of epoxy is allowed. The runner is FULLY PORTED at the stock 163cc volume!
538hp!!!!....575+hp could be had ALL DAY at 13:1 with a REAL head on it!
BUTTTTT....a 383ci would make 675HP!!!! a 406ci would make 700...
horsepower to weight ratio..... reminds me of johnny ricer. funny stuff!
im pissed at myself cause i posted in this thread.
thanks for the link.
Also check out Hotrod's pump gas drags or their Dragweek and see the motors those guys are running. Some of the smaller motors are out running the bigger ones, it all has to do with your combo and making sure it all works together.
Build that 305 and shut some of these people up.
