Will this affect my CARBS PERFORMANCE?
I just bought a 350 and it came with a holley 600 cfm carb w/ an electric choke and i'm going to put it on my '84 el camino (305 w/ 350 goodwrench heads) but I seen that it has this ruff surface on what i believe is the metering block and I wasn't sure if that would affect the carb in any way? I'm going to get a rebuild kit for it if everything checks ok. Thankx
-Strokerpilot
-Strokerpilot
I used to use a high quality stainless steel wire brush about the size of a tooth brush.
Those work good for removing old gasket material like you have there.
Make sure none of it clogs the air bleeds, etc.
