sbc mustang oil leak?
i am currently seeing an oil leak in my motor ONLY when i go WOT. if i go WOT while in park it will not leak. it will only leak if it is underload. I checked the oil dip stick and its fine. other possibilities I have not looked into. valve cover gasket, oil pressure sending unit or distributor gasket. and its coming from the back of engine.
Are these the only possibilities? worse case i guess would be the rear main seal but that would cause an oil leak anytime i hit the throttle.
