Can anyone help spec cam with limited info?
Trying to get the ivo ivc evo evc of this solid roller but I've only got limited info . I tried using a a few calculators but I'm not sure I'm doing it right
Here is what I've got on it.
Unknown brand solid Roller camshaft.
@.020 - 292° - 295°
@.050 - 262° - 265°
Lift. .645. .645
106° Centerline
@.020 - 292° - 295°
@.050 - 262° - 265°
Lift. .645. .645
106° Centerline
Lunati used the .X45" type lift....Comp was mostly .630",.640", etc.
Not really sure if you're looking to identify a mystery cam that you have or
wanting one spec'd for an application
Your general numbers are similar to one's I've used in 12-13:1 406"-408" small blocks and usually will pull strong to 7200 or so with proper supporting mods
383s would get about 6-8 less duration and 355s about 6 less than that @.050"
I prefer to get upper RPMs from light valves, springs, reatiners, rockers and stiff push rods. That way you can shorten up the duration a smidge to build more cylinder pressure/torque. Dynos measure torque not horsepower. The shorter the stroke, the more important cylinder pressure becomes. Don't forget about the advantages of running an AIR pump either. If you can afford one, the less ring flutter from reduced crankcase pressure returns torque from better sealing cylinder pressure(greater number of crankshaft degrees past TDC).
If you mean a vacuume pump I think I can swing it after all this I mean 300 bucks for added safety works for me. It's goin in my 59 Apache. Gonna try n do some bracket racing.
