guys i'm going with brodix heads
hey guys i'm going to get a bordix top end kit for my car today since afr sid it will 8 weeks for there heads and since brodix complete package is the same as afr heads sounds likea better deal and they flow the same #'s so i'm good
Cool...anxiety is killer. If I had the extra cash for a nice set of aluminum heads, I wouldn't want to wait either. Besides, any head will flow just as good as another with the "great equalizer" - nitrous!
guys i'm actually going to get the 18 degree heads instead
here is the specs the intake port is 244cc
chamber volume is 68cc
valve sizes is 2.14/1.60
flow chart is crazy at 500 lift it flow 303 and at 600 it flows 313
i sure *** hope so want the thing to run lower than a 10 in the 1/4 also thinking about going with NOS dual stage shot 150 out the hole and 250 when i'm grabbing for second
That sounds good! I have heard lots of good things about the AFR's but I HATE the wait time! I have also heard that the AFR's don't flow what they claim. But I have Brodix Track1's on my 383 for the simple fact that when I went to buy some CNCed AFR 210's they told me it would be 6-8 weeks and I went to a friend who happens to be a Brodix dealer and he had some Track1's sitting on a cut-away engine sitting in his showroom and he gave me a NICE deal on them.
Josh S.
Josh S.
Josh S.
Josh S.
Hey,
I'm switching over to 18s this winter too. I'm hoping for a mid 9 on motor, in my S-10.
What size cam will you be running, I'm not totally decided yet, but have been hearing some big #s to match these heads.
I'm using a set of old nascar heads, I had some AFR220s last year and ran in the 10s in total street trim. BTW, the 220s are for sale, they flowed over 3, and would be a killer head on a 406-383. I have a 421 and they just weren't quite enough.
Good Luck with your combo.
hey guys...........i see the two of you are going to be in need of a new cam soon. i have 1 i am going to be pulling out of my 427 sbc that has no more than 3500 nearly all street miles on it. the motor came out of an LS1 Tech members car that was in no way a drag car. just a nice, almost Pro Touring looking, Chevelle. not a problem with it in any way, shape, or form. i'm going to go turbo with the motor and will not have a need for this cam. here are the specs...........
-Billet solid roller cam.
-.658/.683 lift, 256/264 duration at .050, 108 lobe sep.
let me know if you have any interest in it and i'll cut you a deal. just shoot me a pm and i'll get back to you.
later,
Dave
later,
Dave
1Q,
The heads are fully ported, w/2.08 Int-1.6 Ex.valves. They are gasket matched to a 1206.
Right now they have prostock springs & Titanium retainers. with 200 long valves, I also have 100 long valves, for a milder setup, I also have a stud girdle and 15 1.6 rockers, one broke last time out.
I went thru on one port and fixed it using the same epoxy the prostock racers use, I got it from Larry Morgan and have put approx. 60 passes with several hours of street time as well with no problems.
These heads have never been overheated or hurt in anyway.
They flow 303@.700-292@.600-284@.500, ex was like 228 & 235.
I am going to do a compression test, and a leakdown test on the motor, then pull it out of the truck, so I will have them off next week.
$1200.00 w/200 long and Springs. $1050.00 w/100 long and no springs and retainers.
ill take um
Whatsup im adam im new to this forum , anyway im building a 427sbc--400gm block with the world kit for 1800$ i know alot but would like some help dont wont to have to keep going through trail and error u know.its going in my vette ,hea i want to know what cam and heads i should use
Adam, that really just depends on how much power you want to make, driveability, reliability, and how much money you want to spend. If you want some damn good heads then get a set of AFR 227's with the CNC work from AFR or a set of Dart Pro 1 230cc heads.. Both are under $2,000 and will make good power with a engine that size. If you dont mind the drivability being kinda rough then go with a big solid roller camshaft.. Something like 250-260 duration with a .650-680 lift. Still street friendly but a monster when you step off in it.
It just all depends on what exactly you are wanting to do with the engine..
