Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
No bottom!
Old Feb 20, 2005 | 07:16 PM
Lurch84's Avatar
Default No bottom!
Okay i just installed a brand new erson 472 lift cam and a torker 2 manifold and i have no bottom end what so ever i thought that with a mild cam like that i should retain some bottom end this thing wont hardly idle with stock converter! Its in a 355 with 8:1 compression. Iam also running this with a 600 cfm edelbrock so that could be the culprit. Any help to this newb is greatly appreciated!
Old Feb 20, 2005 | 10:01 PM
pwr2w8's Avatar
Well I don't know the culprit of your problem here, but what heads are you running?
The carb may be a little small, depending on the rest of your combo. Also, why the low compression? Are you planning on some boost?
Old Feb 20, 2005 | 10:38 PM
Lurch84's Avatar
Nope no boost but i change of heads is in the picture not shure which ones prolly some World products sr torqers, iam running stock heads right now. I would like to run a turbo but i dont have that kinda cash especially since i could be starting school fer long.
Old Feb 21, 2005 | 12:15 AM
Ls1LikeNoOther's Avatar
I would definetly grab a set of edelbrocks..I think they are the best bang for the buck..and you need a converter..your pretty much strangling your car with no converter and a mild cam like that,especially with a 600 carb on it...grab a 750 Quick fuel..
Old Feb 21, 2005 | 12:21 AM
CTSV05's Avatar
Well, an economical fix will be to get rid of the T2 intake, get a hi-rise dual plane.
Then you will need a 2200-2800 stall converter, as well as a gear.
The proper fix will be to put some compression in the motor, and a set of decent heads. But I know how it is being money limited.
Old Feb 21, 2005 | 05:58 PM
AutoRoc's Avatar
If that cam is too aggressive, it won't work well at all with 8.0:1 compression. Get some more specs on the cam and post them. With compression that low, the engine needs a very short duration camshaft to keep the cylinder pressure high. An Aggressive cam bleeds off pressure..pressure that isn't all that high to begin with in this situation.
A Torker Intake is a low rise single plane if I remember correctly. It's not known for making good torque numbers at low RPM. A Simple Edelbrock Performer Intake along with that 600cfm carb should be very tame and torquey. In no way is a 600cfm carb "killing" a mild engine like this.
I'd get a compression tester and see what the cranking compression is. Something in the 160-200psi range would be "normal". The lower it gets the worse it runs, though I'm not saying the higher the better either.
Old Feb 21, 2005 | 06:15 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Your compression ratio is what is killing your bottom end power. Until you raise the comp ratio the other variables aren't really hurting you. If you only bump the comp ratio up to 9:1 you would notice a huge difference. Start with raising your comp ratio and you will notice big changes.
Old Feb 21, 2005 | 07:18 PM
Lurch84's Avatar
I know i need a converter for shure. A coworker told me he would give me a set of 305 heads as a quick fix until i get some money prolly next year.He also said he might have a edelbrock poorformer he also thought the manifold was the problem said he might trade. My gears are 4.10's. And iam looking at a 750 right know(maybe not now), iam also now thinking about taking this out of this heavy 3/4 ton and throwing it in my 73 1/2 ton i dunno. Been out of this racing realm for long time thanks to drugs so i have alot to relearn.Thanks for the help.
Cam Specs:
Erson Prt. # E110421
Lift Duration
Intake .472 256
Exhaust .472 256
Old Feb 21, 2005 | 10:35 PM
hondo's Avatar
these guys are right on,that cam is not too crazy, i agree it wants some more compression, and def switch to a dual plane intake,performer RPM etc.stck with the 600 carb for now.,if its in a heavy 3/4 ton truck its gonna feel even worse,even with 4.10's
good luck
Old Feb 22, 2005 | 12:52 AM
Wnts2Go10O's Avatar
its def the compression, 8:1 is killin ya.
Old Feb 22, 2005 | 07:56 AM
Lurch84's Avatar
The truck came factory with 4.10 cogs. Ok ill look for heads and a manifold today. Thanks for teh help!
Old Feb 23, 2005 | 06:45 PM
Lurch84's Avatar
Well one of the 305 heads was cracked, had them hot tanked and magnafluxed, might have a performer rpm got to call the guy tomorrow. Cant find any matching heads at any local junk yards, besides that i have know found out that its cheaper just to buy aftermarket cuz your going to spend that muc anyway in the machine shop on stock ones. Iam shure you all already knew this.
Old Feb 24, 2005 | 02:45 AM
BOWTIE's Avatar
Well almost everything mentioned so far is credible, but I would throw something else in. If it is running as bad as you make it sound, you may want to pull the timing cover and double check your alignment marks. If you used a multiple key way timing set, it is very easy to lign up with the wrong mark, and in some cases it will seem to run fine, but makes no power.
Old Feb 24, 2005 | 08:38 AM
CTSV05's Avatar
Well, if those duration #s are at 50, then that is a ton of duration for a 472 cam, I like big lift with minimum dur. in a lo compression motor.
That cam was designed for situations like limited circle track classes, where you need that dur. at higher rpms.
If cash is limited, I would advise this. Spend your money on a new intake and a new cam and lifters. You can make acceptable power at 8 to 1.
Look at cams with lift in the 450-460 range, and keep your duration around 220-230 @ 050. You must allow the valves to stay closed long enuf to build cylinder pressure.
I would also buy a Timing Set with the 3 keyway crank gear, and be sure to advance the cam, or choose the advance slot. This will encourage torque output in the lower rpm range.
Old Feb 24, 2005 | 03:20 PM
mzoomora's Avatar
14 Second Truck Club
220-230 is a lot of duration for low copmpression and stock heads IMO. I would probably stick around 210 range unless you are bumping compression to 9.5-1 or better. I do think that 220-230 is a good street cam with some other improvements. As far as heads, maybe some vortecs on a budget. If you want to spend some cash you can hold out for some AFR 195's. They are some of the best flowing street heads out there, and cant be beat for the money. Vortecs, Comp XE268 or 274, RPM air gap, small stall, you will be happy.
Old Feb 24, 2005 | 03:49 PM
Wild85's Avatar
Compression is the problem, that should be at 9:1 at least for that cam.
Old Feb 24, 2005 | 05:10 PM
AutoRoc's Avatar
256 duration I'd more than bet is NOT at .050". It's advertized which puts that camshaft in the VERY mild range so that's not the problem. The Intake and compression are still the worst of the combo.
Vortec truck heads like these guys are screaming about will be great but require a compatible intake. A good place to look is at www.sdpc2000.com
They can set you up with the correct top end package. Heads/Intake/Gaskets/Bolts..
Old Feb 24, 2005 | 05:44 PM
mzoomora's Avatar
A head change would probably build up his compresion since he probably has stock smog heads with 76cc chambers. 305 heads would be a quick fix for compression, but not if they will need some work. If an intake is gonna be needed anyway, Vortecs arent a bad idea. A intake for them is about the same price as any small block. Deffinetly check Scoggin Dickey for Vortec stuff.
Old Feb 24, 2005 | 06:51 PM
Lurch84's Avatar
Ive been checking out theyre vortec packages but i found some canfeilds on ebay for 500 or so right now the bid might go up kinda scared to buy used heads lol. Atleast my coworker didnt charge me for the 305 heads after i found out one of them were bad. I messed with the carburator and timing today pulls real nice from 2-6000 rpms very nice when i get out on the highway cuz iam running like 3100 to do 70 mph before it lacked alot with the stock cam know it has power which is what i wanted but i lost my bottom end but iam getting used to it lol. What size exhuast should i run iam running 2 1/2 with 40 series flows turn downs sounds good just though about running a bullet muffler lol i cant get no tickets for 60 days.Yes it did have smog but it has been smoged out with a few wrenches and headers. The cam has 228 @ 50 duration. What stall converter should i run? Well the new timing chain that i picked up had no mark on the crank gear so i just pointed the dot on the cam sprocket strait down,i ve dun three other cam swaps with succes in sbc but its been awhile. I just gave that comp ratio as a base becuase the engine was not built under my authority and i have no idea but the engine was rebuilt relativaly close to stock wich usually range from 8 to 9(i think).
How would i go about advancing the cam with a three keyed crank gear? If i did that and change the manifold with this cam still in would it bring the bottom in back up.
Old Feb 26, 2005 | 06:45 PM
BOWTIE's Avatar
The crank gear has to have a mark on it. If it does not, you may have it on backwards (mark towards the crank so you can not see it). If that is not the case, return it, it is defective. The only way you will be able to know if you have the cam installed correctly with out a mark would be to have it degreed (in fact even with a mark you can usually find it off some but at least it is in the ball park). In the case of a multiple key way crank gear you should have 2 sets of marks for each key way. One denotes which key way to use, and the other which will be a duplicate of the one next to the key, will be the one you line up with the mark on the crank gear. Just FYI, the mark on the cam gear does not line up with the keyway either. I guess if you had to you couls use the stock crank gear and line it up with the key way on the new one and make a mark where the stock one mark is, that would be much beter than just guessing. Have you checked your cranking compression yet. I am not an expert, but I would think it would be around 130-150 psi (+/-) with that compression and cam. If it is a lot higher (like 180+) or a lot lower (110-) then I would seriously consider pulling the timing cover and rechecking your cam timing, because I would almost bet your timing is off.
