Carb'd 305 Comp.?
Carb'd 305 Comp.?
Im starting to build my carb'd 305. my ? is, can I ditch the computer, or at least not have it control the air/fuel on the motor? Its an 87. If that helps.
Im planning on gutting the whole car and turning it into a nitrous junkie. Streetability and gas mileage is not an issue. What are my options? Thanks in advance.
Originally Posted by towood
You will have to use a none computer carb., and dist. It should work then.
You will have to dump the dis. if you get rid of the compuer carb. A regular HEI dis. works great. This is what we did when we swaped out a 305 for a 350 in my friends 87 camaro.
