Universal electric fuel pump OK?
Am looking @ a universal (low pressure, around 2 PSI) line mounted electric fuel pump to feed the carb on my Gen 1 350 project. Am told it will work great. Anyone have experience using an electric fuel pump in a carb application please comment. Thank-you
My experience is that a small block (mild) needs at least 5lbs of pressure. I ran a 13.5 to 1 400 sbc and used a manual pump with 8 psi and -8an fuel lines..I found that changing the fuel lines from 1/4" to 1/2" made a HUGE difference...hope this helps...in my opinion, a 2 psi pump won't cut the mustard.
I have the holley mechanical (i know we're talking electric here) 110 on a fairly fixed up 350 that I have and it works good. The reason I upgraded to that is the pump that was on there before couldn't supply the motor enough fuel in 3rd gear while racing. So, i went with the holley mechanical 110. Even at that, people I know with fixed up motors will go pick up the holley blue electric fuel pump with the regulator at the local o'reilly's. Just a suggestion.
