327 on nitrous
327 on nitrous
here's the deal. my buddy has a 76 nova with a 327 out of a 69 camaro. its some special block. well anyways before he hooked up his nitrous kit (sniper kit) the car could blow the tires out from under it. now he put the nitrous on it gapped a set of tr55's i believe to .25 and the car kinda bogs when you step into. btw this is on all motor. could the plugs be gapped to much and this is the reason it bogs. it cant spins the tires till about 3000 rpm. its got vortec heads and a small cam also. thanks for any help!
he needs to tighten up the gap by .010 and then jet it up a couple of sizes. then he needs to lose about 2-3 degrees of timing for every 100 hp of nitrous hes running.. im really suprised nothing bad happened with his motor.
