How Much Rwhp Would this set-up make
Just wondering (estimate) on how much rwhp or horsepower (fly) this set-up should make.
67 Camaro full weight
355 sbc engine
10.6 compression
speed pro hyperutectic pistons, teflon coated skirts
eagle cast crank
eagle sir i beam rods
comp cams solid flat tappet cam 532/555 lift 106 lobe, duration @.50 250/260
Dart 200cc iron eagle heads, 63 cc chambers
Hurricane pro high rise intake
trickflow chrome moly push rods
750 holley carb
4:10 gears
355 sbc engine
10.6 compression
eagle cast crank
750 holley carb
4:10 gears
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Similar to my set-up I ran but with 10:1 compression, 195 cc canfield heads, crane solid cam 518/536 lift, Victor Jr intake and 650 carb through a TH350 and 3400 stall convertor. 327 rwhp/340 rwtq. Depending on trans and convertor (if automatic) I'd say 340.
Derek
Derek
re:
The car is a automatic. Full weight camaro. 3800 convertor. Is there anything basic I can change to get more horsepower?? What should this setup run 1/4. I bought this engine off a guy who had it in his full weight 88 monte carlo ran low 12's with it - that was with a 4:56 gear.
7 Second Club
1 Post
Good luck with it!
Derek
