help with 305 vortec
G'day I have just joined the site, it appears there are some knowledgable people on it and I need some help with a 97 305 vortec truck engine I bought to put in a rodeo ute I have. I have found not many people in Australia know much about the later model chev motors.Can any one help with the following question.
I have bought a power plus cylone manafold and I have an electric water pump and it said in the manafold installation that on 96 and later vortec engine ( that does not have bypass in block )you must run a coolant bypass line from the manafold to the 5/8" hose nipple on passenger side of water pump.How do you tell if it has internal bypass and the electric water pump only has the one outlet to the rad . what does this bypass do and is there a way to still use electric pump.Also can any one help with specs on this motor or where can I find them.Thanks for the help
im not sure on the bipass i really havent heard anything like that befor on a sbc, bbc have a hose from the manifold to the waterpump, the specs on the 305 are
bore-3.736
stroke-3.48
head cc- about 58cc
not sure what else your wanting to know hope this helps
Ryan
bore-3.736
stroke-3.48
head cc- about 58cc
Ryan
x2 I dont see how it can be done on your current setup nor the reason, And just a 305 in a UTE, Wheres the big block and supercharger!? jk Ive watched alot of aussie vids... you guys are freakin nuts!!
I needs coolant flow when the thermostat is closed. A bypass will bleed air through and provide more consistent temperature.
Three 1/8" holes drilled around the edge of the thermostat is usually suffecient bypass.
