Group purchase on Moser and Strange Rearends..
price on Moser 9", 31 spline, True-Trac, 3-channel, 3.50 gears, unpainted alum & iron prices please. Also I will need stock position LCA and swaybar attachments.
Also let me know how much a new driveshaft to fit would be from you. Thank you.
wait a sec, you can do 3channel with a 9" and still have abs? Where is the pickup wheel for the speed sensor? if so
9", 4.10, 3 channel ABS, Detroit TruTrac, 31 Spline axles, drain plug, bare metal finish
and either way quote for a 12bolt with 33spline axles and same setup as above 9"
shipped to 96706
shipped to 96706
#36
Still waiting on a response...would like to know the dif in cost between Moser and Strange with the same options. 33 spline, non spool, OE wheel studs, standard length, etc. Want a drop assembly for my 98 TA that my brakes will work on. Thanks in advance.
