BMR Springs for $159 a Set......
LS1Tech Premium Sponsor
....with the purchase of $99 or more of BMR product.
That's right!! A set of 4 BMR springs for the 4th Gen (part number SP001) are on sale for only $159 with the purchase of another BMR product!!
We recommend an adjustable Panhard Rod (PHR002) whenever you lower the car to re-center the rear axle housing. However, all BMR product applies to this offer.
BMR springs have a 1.25" drop on both the front and rear. Front spring rate is 550 pounds/inch linear. Rear spring rate is 160 pounds/inch working rate.
You must be a member of LS1Tech to take advantage of this offer. Please tell the Sales Tech your member id when you call.
You can place your order on line, but the original price will come up. Don't worry, we will adjust the price before we charge your card. Place orders online here:
http://www.gnetworks.com/v4/go.gnf?session=9a9bc39988e1f87ca8d7b2d4646ec378&s= bmr&t=&product=11678&n=default&d=products&listTemp late=
- The cost of the product must meet or exceed $99
- Must be purchased directly through BMR
- Non-BMR product such as shocks and brakes do not apply to this offer
- Do other suspension companies test 100% of their springs on a CNC Spring Tester?
- Do other suspension companies offer a Lifetime Guarantee against spring sag?
- Are other springs stress relieved at 750 degrees F?
- Are other springs shot peened to remove surface stress?
- Are other springs Proudly Made in the USA?
