Strange 12 Bolt/Dana S60 Rearend Group Purchase
(Note: This GP has ended but see our posts in this thread from 9/19 for details on how to get a great deal!!!).
Is your rearend about to take it's last trip down the track? If so, we can help you with a Strange 12 bolt or one of the new Dana S60 rears! We're running a group purchase that covers both of these.
12 Bolt -
Gear ratios available are 3.42, 3.73, 3.90 and 4.10. The 3.90s will be noisy so Strange doesn't promote this one. This rearend now comes standard with the Super Strength posi. Each one is shipped ready to be installed. You will just need to swap the brakes from your current rear. Shipping is freight collect for this product so you will need to take care of that with the driver when he delivers.
GP prices -
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2219.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2219.99
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Dana S60 -
Dana S60 features -
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
You will need to send your brake backing plates in just before the rear is built so they can be built into the rear. We can sell a new set to you separate. The stock driveshaft will need to be shortened by 1.625".
The following gear ratios are available - 3.54, 3.73, 4.10, 4.30, 4.56, 4.88, 5.87.
The weight difference between Dana 60 and 12 bolt is 20-25 lbs, the Dana is heavier. Dana rear is fully assembled with posi weights around 215 lbs and 12 bolt is around 189 lbs (weight with brakes). The weight difference between 12 bolt and 9" is about 12-15 lbs the 12 bolt being lighter.
Ring gear sizes:
12 bolts ring gear only 8.875 OD
9 ring gear is is 9" OD
Dana has ring gear of 9.75 OD which is alot stronger than 12 bolt & 9".
The standard Dana gear (not Pro) can withstand close to 1200 RWHP.
The True-Track is posi is standard along with Power-Lock. These are good for about 600rwhp. The Dana's posi is alot stronger than a 12 bolt and the 9". This is because the Dana Posi's are 35 spline, 12 bolt is 33 spline and the 9" is a 33 spline.
GP prices -
PRSF05 Strange Dana S60 $2049.99
Driveshafts for Dana S60
U1699 Strange U1699 driveshaft 3"x.083" DOM chrome moly driveshaft with H.D. U-joints $209.99
U1700 Strange U1700 driveshaft 3"x.083" Seamless chrome moly driveshaft with High Imp. U-Joints $329.99
U1702 Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints $289.99
5 or more orders are required by Tuesday, September 12th for this to go through. We will start ordering these when we have 5 orders in so it will be good to order early! This GP covers all rears that Strange produces so let us know if you need a rearend for a vehicle that isn't listed here.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763.
Have a good day!
12 Bolt -
GP prices -
Dana S60 -
Dana S60 features -
35 spline axles
HD Posi
Chrome Cover
3 or 4 channel ABS
Ring gear sizes:
GP prices -
Have a good day!
strange rears
I have a few questions
1) Will my UMI adjustable torque arm work with the 12 bolt and the s60?
2) The same thing for my UMI panhard bar?
3)Are both a direct bolt in or do I have to make them fit and will my stock driveshaft (STEEL) work with these?
4) How much will shipping cost to 33033?
5)How long does it take from order to delivery?
I am VERY interested in purchasing one of these! Thank you.
The UMI parts should work with these. We haven't fit them with either of these rears to say for sure but the stock/aftermarket suspension components will usually bolt up. The stock driveshaft will need to be shortened by 1.625 to use it with the S60.
The rears are shipped freight collect so you would take care of that with the trucking company when they deliver. Shipping is usually in the $125. - $250. range. Delievery time will depend on how Strange is doing with production when everything is ordered. They should take at least 1-2 weeks to ship.
We now have 3 orders in.
Originally Posted by Zitty'sZ
I just called to order one of rears and the girl I spoke to said that you are NOT running a group purchase.What kind of circus are you guys running here?
It's a three ring circus . Lions on one side, elephants in the center and those crazy monkeys riding motorcycles on the other side.
Did you ask someone about a VaraRam group purchase this morning? Someone here asked me about that around 11 or so east coast time. I told her no. She let the person on the phone know about that. He told her that the GP was posted on September 1st. That is the same day this GP was posted. She confirmed with him that there is no Vararam GP
No I asked about the strange rearend group purchase and she said no there was no group purchase and I repeated to her that on LS1 TECH.COM there is a thread dated 9-1-06 stating a group purchase on ALL strange rearends and she said no that is an old thread and the conversation ended! I have called your bussiness 3 times since that conversation trying to ask a few more questions BEFORE ordering a rear, but no one will return my calls and yes I have left my name and number TWICE! Now thats what I call customer service!! Have a nice day !!!
I don't know... I heard what she was saying on the phone and I'm the one that told her that it was probably an old thread so I know which call it was. I was covering the call backs today and there were no calls that weren't returned as of 4:30. Unless for some reason your calls didn't make it onto the list but they are usually done right away.
Restricted User
Tbyrne, I have the $2049.00 for the S60 rear right know. My question is, can I order the rear right now (since there is a 2-3 week lead time) and have it in the que and then in a couple of weeks send in the cash for the backing plates and the shorter driveshaft? Also, do you guys sell a good torque arm that would work with my custom exhaust pictured below?
FCar2000TA: Let us know if you would like to get in on this.
