Polished Stainless Header and Y pipe
#122
We got ours put in the other day..
Pax side header went in without any issue..
Drivers side header needed a bit of help.. I had to "massage" the K-member and BFH the floor to keep it from banging..
I have the Y-pipe but I'm not sure if I am going to use it..
#123
BFH the floor??? wut? lol also i forget what it was but, what do you guys suggest i use to wedge between the floorboard and Y on driver side to reduce the noise of them sitting against each other?
#124
Just get a piece of 1" heater hose however long you need it for where the pipe is hitting and slit it down one side and open it up and slide it between the pipe and the floor. You may have to pry the pipe down a little to slid it in.
#133
Installing my set and having some problems. Seems the drivers header doesn't hang low enought to get the y pipe on or the y pipe is missing a bend to slide onto the header. Anyone else have this problem?
#134
Yup. After some hesitation, i shipped the header back and they repaired it for me.
