LS2 Billet rails and cable bracket They are here and ready to go the LS2 billet rails and billet throttle cable bracket. Complete kit LS2 intake, Billet rails, Billet cable bracket, TPIS TB, injector O-rings and all hose and fittings to bolt directly to you factory feed line. Complete LS2 Kit $1150.99 + TB core Billet LS2 Rails $199.99 Billet rails w/ all fittings and hose to factory feed line $340.00 Billet throttle cable bracket $99.99 GM LS2 intake $249.99 GM injector O-ring kit $29.99 TPIS 90mm LS2 TB $489.99 + TB core Have a great day Nate https://ls1tech.com/forums/attachmen...chmentid=17859 https://ls1tech.com/forums/attachmen...chmentid=17875 https://ls1tech.com/forums/attachmen...chmentid=17876 https://ls1tech.com/forums/attachmen...chmentid=17877 https://ls1tech.com/forums/attachmen...chmentid=17878 |
explain to me the tb core? also how does the 2 fuel lines hook up? |
Awsome Nate.... I replied in the other thread also..... :jest: :jest: Kyle |
TPIS uses parts from your original TB so we need it when you buy one of these. And here is a picture of the lines and it has a connector for your factory feed line. Wassup Kyle how have you been? How do I get you to banner my logo? ;) |
Any specials for the billet LS1 fuel rails? |
I can get you the LS1 rails for $135.00 Nate |
Originally Posted by Nasty N8 I can get you the LS1 rails for $135.00 Nate |
No I have an install kit and rails is $300 includes every fitting you will need. Nate |
Picked mine up today! Looks awesome. I can't wait to bolt it down to my new engine. Thanks Nate, Angelo :cheers: |
Is that TPIS TB the oval 90mm, or a round 90mm? |
The TPIS is a 90mm round TB. It is the best Quality. Nate |
so how much is the core? |
Nothing if we get your TB or $100 Nate |
© 2024 MH Sub I, LLC dba Internet Brands
