dlove's 414 Powered 00 z28 2000 Chevrolet Camaro Z28 White ~110k Miles Sponsors: All out of pocket and in my garage. Factory options: A4, Hard Top, Leather, All Power Options Engine: LS3 shortblock with katech rod bolts ~4k miles Stock Port L92's, .040 Gasket. Patriot Extreme springs. My own ported l76 intake / NW 92mm TB. LG G6x3 cam SLP 1 3/4 headers, 12'' turn downs off the headers No Thermostat ASP Crank Underdrive Pulley NGK TR6 Spark Plugs, MSD Plug Wires Full EFI Live SD tune. Tuned by myself. Transmission: Powerglide transmission, built myself. Circle D- 5C 5000 stall BMR crossmember Stock steel Driveshaft Rear End: Strange 12 bolt, 4.11's, spool Suspension / Brakes: Custom Welded Subframe Connectors Custom chromoly 6 point QA1 R's with Afco 275 springs in front Profab K member Madman 1 off solid motor mounts Madman manule rack Burkhart 2'' drop spindles Strange double adjustable rear shocks with v6 springs SJM Tubular Lower Control Arms with Welded in Relocation Brackets Madman Torque Arm Strange Manule Master Cylinder Strange front and rear brakes Appearance: Harwood black lift off SS hood. Greg Weld front wheels with ET fronts Rear Summit ProStarts with lots of different tire combos lol Smoked headlights and corners RCI plastic seats Lightweight carpet Harlen shiftlight in center vent B&M Pro ratchet shifter Grant steering wheel Planned Future Modifications: Upgrade Headers Performance Statistics: N/A best with the LS2. 1/4 Mile: 10.46 @ 128, 1.47 60ft About This Car: Pretty much a drag only car that I drive on the street more than the track. Race weight is 2800 with me in it. |
some vids my car NA with the ls2 vs a 10.6-10.8 truck http://www.youtube.com/watch?v=PfvDDd7Cd_o some old n/a runs, car was anti squating hard http://www.youtube.com/watch?v=gWvHNcicv9Y fastest pass to date, first day the tracked opened for the season, was not holding anything http://www.youtube.com/watch?v=4TsTDz-a1wI |
new N/A best tonight as well 10.46 @ 128 with a 1.47 60' |
some new pics. bigger rear tires are waiting to go on, as well as lower the rear. all the dust is from it being in a cave https://img.photobucket.com/albums/v...r/IMG_0190.jpg https://img.photobucket.com/albums/v...r/IMG_0261.jpg https://img.photobucket.com/albums/v...r/IMG_0260.jpg https://img.photobucket.com/albums/v...r/IMG_0243.jpg https://img.photobucket.com/albums/v...r/IMG_0194.jpg https://img.photobucket.com/albums/v...r/IMG_0130.jpg |
sold the LS2. LS3 soon... |
Heads are just getting milled, and put on unported. cam is the g6x3 |
It runs :devil: |
Pretty much how she will look. Need to clean up a few things here and there though. http://i125.photobucket.com/albums/p.../IMAGE_013.jpg http://i125.photobucket.com/albums/p.../IMAGE_015.jpg http://i125.photobucket.com/albums/p.../IMAGE_017.jpg |
newer pics. added a few things. |
Some of my new parts got here today MADMAN Torque Arm and Manual Rack http://i125.photobucket.com/albums/p.../IMAGE_038.jpg |
More parts came in. https://i125.photobucket.com/albums/...gregwelds1.jpg https://i125.photobucket.com/albums/p41/azxic/15x10.jpg For the front. https://i125.photobucket.com/albums/...tlestrange.jpg Double adjustables for the rear https://i125.photobucket.com/albums/.../IMAGE_050.jpg |
http://i125.photobucket.com/albums/p...1236230456.jpg Strange 12 bolt w/ strange brakes Narrowed 3'' per side spool, 4.11's lightweight yoke lightweight axle ends Aluminum cover The weight with fluid is...... 180lbs My stock 10bolt with auburn limited slip and stock brakes: 205lbs |
http://i125.photobucket.com/albums/p41/azxic/011-1.jpg http://i125.photobucket.com/albums/p41/azxic/012-1.jpg http://i125.photobucket.com/albums/p41/azxic/013-2.jpg This came out of the intake http://i125.photobucket.com/albums/p41/azxic/014-2.jpg http://i125.photobucket.com/albums/p41/azxic/015-1.jpg http://i125.photobucket.com/albums/p41/azxic/018.jpg |
I found what did my motor in. The vvt oil pump. Found a spun bearing in the bad cylinder. Looks like I probably sucked the pan dry. The extra slop in the rod cause it to come up more in the cylinder and hit the valve. Total damage: 1 broken in half valve 1 busted lifter, all the rest apear worn 3 bent valves 1 missing piston 1 piston broken off the rod 2 bent rods 1 spun bearning 2 cylinder sleeves with lots of chunks missing cracked block camshaft scored on a few lobes both heads need lots of work windage tray bent Crank scored up Oil pump burnt up |
https://i125.photobucket.com/albums/...1242699158.jpg https://i125.photobucket.com/albums/...1242698178.jpg https://i125.photobucket.com/albums/...1242698379.jpg https://i125.photobucket.com/albums/...1242698551.jpg Need to pull the trim off the door and work on getting the fenders lined up. I also have an SS wing on the way! |
| All times are GMT -5. The time now is 12:30 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
